Old 09-20-2017, 10:05 AM   #1
JBauer's Avatar
Hardtop hoist?
Anyone made their own hardtop hoist? If so share how you did it. Seems like it wouldn't be too difficult.
Old 09-20-2017, 11:46 AM   #2
Artist, 986S tinkerer
NewArt's Avatar
I used a kayak hoist which I got from Amazon.
Old 09-20-2017, 01:04 PM   #3
JBauer's Avatar
Great idea! I'll check into that. Thanks
Old 09-23-2017, 09:17 AM   #4
JBauer's Avatar
Test fit 😀
Got my kayak hoist and i think it's going to work just fine. Need to get another strap or longer straps but alls good. Thanks for the idea NewArt !
Old 09-23-2017, 10:43 AM   #5
RobertF's Avatar
How much does the top weigh?
RobertF is offline   Reply With Quote
Old 09-23-2017, 10:45 AM   #6
NewArt's Avatar
You will need to support the back of the top. there is very little weight at the front.
Old 09-23-2017, 12:15 PM   #7
JBauer's Avatar
About 65 lbs. I'm going to buy a couple more, probably longer straps. This was just a test.
Old 09-23-2017, 06:27 PM   #8
My hardtop lift ( factory ? ) has a padded bar with hooks on the end . The bar goes through the window openings from side to side and a lift strap hooks to each end of the bar . Then there are two straps that hook to the back of the top under the window. More weight in the back section so it needs to be supported . Basically a boat winch and you just crank the handle and the top raises or lowers . Works great I can load/unload the top by myself .
Old 09-24-2017, 01:43 PM   #9
JBauer's Avatar
Hoisted it off, drove out from under it, came back, put it back. Creepy as hell �� Going to get a better rope before I do it again. The rope that came with it is already fraying. Need to get some padding too.
