Old 09-11-2017, 02:44 PM   #1
Can the AOS vent line cause vacuum leak?
Title says it all - trying to troubleshoot a vacuum leak in a '97. Newish AOS that is functioning fine (I know it is not the problem) could the AOS vent line that connects the top of the AOS to the intake / throttle body, if not properly sealed, cause a vacuum leak at low speed that would trigger a CEL? Could it happen due to an ill fitting o ring on the end of the vent line?
Thx-
brewerbry is offline   Reply With Quote
Old 09-11-2017, 04:17 PM   #2
jsceash's Avatar
Yes there are o-rings in in both ends to seal off both residual oil mist and air.
Old 09-11-2017, 06:30 PM   #3
Wrap some self sealing tape around the connection and see if the behavior changes.
Joe K. Peachtree City GA
2001 986 Boxster S, Silver with black interior.
blueflames is offline   Reply With Quote
Old 09-12-2017, 04:46 AM   #4
kk2002s's Avatar
Yes. I Had vacuum issues when I could not get a good seal on TB side of hose. Should replace with new AOS. Cheap part
Seal Grey
Old 09-12-2017, 06:40 AM   #5
I just changed this part. It's only $28.00 and easy to remove and install.
Any leak from this hose will effect the way your engine run.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
