Old 08-11-2017, 07:06 AM   #1
A/C issues
I recently bought a '99 model and the A/C doesn't work well. Does anyone know if the radiator fans should run whenever the A/C is engaged regardless of engine temp? Mine do not. They only run when my engine gets to about 185 degrees.
TomKimbrough is offline   Reply With Quote
Old 08-11-2017, 07:11 AM   #2
Multi-Boxer Driver
Deserion's Avatar
Yes, the low-speed fans should come on with the A/C compressor engaged (or high-speed if it's hot outside, not certain on the exact temp.).
Have you connected pressure gauges to the system yet? Could be the refrigerant is a little too low to trigger the fans.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 08-11-2017, 07:34 AM   #3
A/C issue
It's on my list to do tomorrow. Thx for the suggestion
Old 08-11-2017, 07:38 AM   #4
Checking pressure and possibly adding refrigerant is on my to-do list for tomorrow
Old 08-11-2017, 07:50 AM   #5
There are multiple threads here about the foam rotting off the climate control doors/baffles. The primary effect is that the AC works poorly. Do a search.
1941 Dodge Luxury Liner Coupe
Old 08-12-2017, 06:53 AM   #6
The fan has to come on when you turn on the AC in any car as the condenser will not function efficiently unless there is air going across it and you can actually fry the compressor as it will create too much pressure. Having said that there are many reasons your ac will not come on. Low pressure, bad relay, bad switch, bad pressure sensor and the list goes on. Check refrigerant first with a gauge and go from there.
bwdz is offline   Reply With Quote
Old 08-14-2017, 03:18 AM   #7
A/C issues
Thanks - I added refrigerant and it's now working well
Old 08-15-2017, 11:13 AM   #8
Jacksonville, FL repairs
Hopefully, Chris/Deserion will answer this since he lives nearby, but does anyone have a preference between Omega Motorsports, Pulse Racing and Technical Dimensions in Jacksonville, FL?
