Old 03-13-2017, 07:32 AM   #1
Oil Weep
I have a small oil weep as the pictures tell the story, is this something that can be torqued ? and also trying to id what this “seal plug is” Thanks in advance getting ready for spring!!!!!!!!!!!!
osw986 is offline   Reply With Quote
Old 03-13-2017, 09:02 AM   #2
Most likely Spark plug tube O-rings are leaking.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
Old 03-13-2017, 11:10 AM   #3
the picture is not very clear, but that seems to be a chain tensioner?
If so they can indeed leak, but you have to lock the engine at TDC, and lock the cams before removing it to replace the o-ring and the crush seal.
Old 03-14-2017, 11:24 AM   #4
Project Addicted
jcslocum's Avatar
I'm guessing this is on the pass side (USA) of the car?? If so, then there is a lot of things that could be leaking above there and that tensioner probably isn't the likely culprit.
Oil can be leaking from all of these places. AOS, Flex Pipe & oil fill pipe.
You can see the mess below all of then before it gets to the tensioner area.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
