02-07-2017, 07:47 AM
are these tops supposed to be 100% water tight?
i am in the process of having my rear window replaced,
while i had a trouble light under the clam shell i realized i could see light from out side the car with the roof full deployed and the clam shell down???
it is on both sides where the roof / clam shell weather stripping stops and just rear of the little triangle looking body piece sits and forward of the drain hole. (cleaned)
if i look straight down on either side of the car i can actually see inside the clam shell compartment.
is this normal?
02-07-2017, 08:15 AM
Multi-Boxer Driver
Is the seal on the bottom bow of the roof still intact?
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
02-07-2017, 08:23 AM
Project Addicted
There will be spots where the top gaskets won't meet with the rest of the bodywork. That is why there are pans and drains back there to keep clean. 99% tight would be great if they can catch the other 1%... This is why so many cars end up with drowned alarm system ECU's. The drains get clogged and flood under the seats.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
02-07-2017, 04:11 PM
ok, thanks
02-07-2017, 04:40 PM
I am my own mechanic....
I carry a couple soft rags. Drivers window.
'08 VW Touareg T-3 wife's car
02-07-2017, 05:03 PM
^^^ What he said ^^^
The top shouldn't let water leak into the passenger compartment but water will get into the area behind the top by the clamshell. This is why they have drains back there. But if you're getting water into the passenger compartment, then you have a problem.
02-10-2017, 12:19 PM
rayF
Your post states that you are having your rear window replaced. Is that the plastic one? If so, where do you go for that and how much are they charging you. My vinyl window is mostly out and I was thinking of just buying a new top with glass instead of even trying to repair it. Just checking options. Thanks
02-10-2017, 12:42 PM
Here is an excerpt from the owner manual for a 986.
Somehow for Porsche a tiny leak here and there is considered normal. Specially if you see a leak just after washing your car.
02-11-2017, 03:24 AM
the window cracked/ split so this is a need not a want project.
i started off at the auto glass places in town and figured out pretty quickly THAT WAS A NO GO.
they wanted 200 to replace the window ok, but they wanted to remove and reinstall the roof and that would be extra and would not give me an estimate on time or price.
plan A i am attempting to-replace it myself ( 50 Canadian)
i can already tell you this is not fun, it will be functional but i am still adjusting for that factory look.
plan B if i cannot get plan A perfect, i am going to strip the roof, and try to reinstall-it, if i can do that correctly i am going to buy a new roof with a glass window. (800 Canadian)
plan C if plan B is too hard to get perfect, and all else fails, i will start looking for a hard top. i estimate around (3000 Canadian with shipping)
02-11-2017, 08:33 AM
2003 S, Arctic Silver, M6
Hey Madmac, where have you found a glass window roof for 800 CDN. Just curious since I haven't seen anything close to that amount. 1200+ seems more the norm.
Thanks.
02-11-2017, 02:34 PM
02-12-2017, 09:14 AM
Cool. Thanks!
02-12-2017, 10:10 AM
Let me know how these glass window tops work out! OEM?
986 00S
