Old 01-13-2017, 10:37 AM   #1
coolant
Have watched several videos on YouTube re: coolant issues and still am not sure of the best solution. Have drained the radiator, flushed it with distilled water and am ready to refill. What is the best coolant to use? Am I forced to use the Porsche blessed option? I did buy a vaccum to insure I got all of the air out. Not sure if that worked correctly. Exactly how much fluid should the system hold (98 Boxster)? Thanks.
ray_pilot is offline   Reply With Quote
Old 01-13-2017, 10:47 AM   #2
Multi-Boxer Driver
Deserion's Avatar
You can use the Volkswagen G12 (pink) coolant, works great in aluminum. Same for Zerex G-05 (Mercedes-Benz supplier).
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 01-13-2017, 11:05 AM   #3
JayG's Avatar
This has been discussed many times and there even was a very recent thread, last week or so
The total cost difference between Porsche coolant and the others probably for the 6 gallons of 50/50 is maybe $30-$40
Just buy the Porsche stuff at around $35/gallon and distilled water from wallmart @ $1/gal to dilute it.
Its not something you have to change very often.
Old 01-13-2017, 01:30 PM   #4
You want OAT.
See Pedros Garage for a comprehensive review.
Walmart coolant works fine.
Be more concerned about w/p weepage and burping/AirLift.
http://www.coolantexperts.com/coolant_overview/oat_coolant
Old 01-13-2017, 01:39 PM   #5
kk2002s's Avatar
What came out. Pink?
If so put Porsche pink back in. No compatible iissues to deal with
If green, original Porsche was green. Mine was green and I did 2 flushes replacing with Porsche pink
I suggest using Porsche pink
Just my opinion
Seal Grey
Old 01-13-2017, 02:41 PM   #6
Pdwight's Avatar
Gold
Mine is gold colored, is the newer Porsche coolant ??
Old 01-13-2017, 04:26 PM   #7
Come on ,this chemistry not color co-ordination. Just buy OAT coolant.And oat is not a color!
Old 01-13-2017, 06:27 PM   #8
Thanks, I had looked at coolants and nowhere could I see where it stated organic or not. Have looked further and there are several. Will use the OAT Prestone Extended Life. Hopefully tomorrow.
