Old 12-19-2016, 10:29 AM   #1
jeeper31's Avatar
Noise from rear
I had my 09 Boxster out the other day and I thought i heard a scraping noise coming from behind me. The car was running fine so I thought maybe it was the seat rubbing against the console. The noise seemed to get a little worse as the day went on. When I got home i let the car run and walked around it. From the outside it sounds more like a clanging noise and seemed to be coming from underneath the car in front of the rear passenger wheel. Is there anything there that can be loose? I have been sick and it was cold so I didn't get under the car to see. Muffler clamp maybe?
Thanks.
Dan
jeeper31 is offline   Reply With Quote
Old 12-19-2016, 01:06 PM   #2
Take it to your Indie and get it up in the air to inspect .He'll probably diagnose and estimate on the spot - before anything drops off!
Old 12-19-2016, 01:51 PM   #3
only 5.95 might be a cost saving 1st step. Sorry to hear you have noise from the rear.
fanguy is offline   Reply With Quote
Old 12-20-2016, 02:33 PM   #4
tonycarreon's Avatar
had the same thing a few years back (few...many) that at first i thought might be the heat shield. turned out to be a bolt wasn't tightened after i replaced the alternator...
