Old 11-30-2016, 03:08 PM   #1
njbray's Avatar
What's this noise?
I get this noise (sounds like a vacuum cleaner) when starting from cold. It goes off after about 20 seconds. No smoke and no cel.
Any ideas?
https://www.youtube.com/watch?v=yCEh3611i_M
njbray is offline   Reply With Quote
Old 11-30-2016, 03:14 PM   #2
still plays with cars...
BoxsterSteve's Avatar
Your SAI pump is crapping out.
You can take these apart and lube the bearings. They dry out and make noise a while before they die.
Six speed 2000 Boxster S
Old 11-30-2016, 03:48 PM   #3
Depends on how loud it is. Its normal to hear a faint whine.
Anker
1941 Dodge Luxury Liner Coupe
Old 11-30-2016, 04:00 PM   #4
07 Carrera S Cab
Boxtaboy's Avatar
Watching the video, it's abnormally loud. If he's in the U.K., is there even an SAI?
Old 11-30-2016, 04:01 PM   #5
That's definitely bad/dry bushing on the secondary air pump. Easy fix and cheap if you take it apart and grease them before they burn up the motor.
Old 11-30-2016, 04:14 PM   #6
njbray's Avatar
Thanks for the quick replies.
I guess I have a project for tomorrow! It looks fairly easy to remove!
Are there any write-ups for this and what type of grease is required?
Old 11-30-2016, 05:09 PM   #7
Many VAG products use the same SAI pump. Here's a DIY I found where an Audi owner gutted his and nursed it back to life.
WRITEUP: 2.7T Secondary Air Injection SAI Pump rebuild - AudiWorld Forums
Or check with Woody... he may be able to fix you up with a decent used one.
