Old 10-22-2016, 03:37 PM   #1
1st Oil Change
Hello Everyone
I Bought this 2001 Boxster 1 week ago
I just got insurance and title work done.
Today I decided to change the brakes and Oil
All 4 pads were worn through to the sensor
Shot of the pads ( I had to buy 4 sensors)
All went well with the breaks... now onto the oil change
Good news previous owner replaced the original oil pan plug with a magnetic one
Shot of it with new crush washer
Next came the filter I bought a manns cartridge filter fully expecting to find the stock casing that holds the filter
I found this instead
Can anyone tell me if they have seen this before and will it harm the boxster?
I believe the P.O. screwed in an adapter that allows the K&N to screw on
Much shorter than the stock one
Any Advice?
Mike
mike914 is offline   Reply With Quote
Old 10-22-2016, 03:49 PM   #2
jsceash's Avatar
Many have done something like this to get better filtering the stock filters bypass and it allows dirt to recirculate to some extent.
Old 10-22-2016, 03:50 PM   #3
911monty's Avatar
Looks like you bought a well cared for car. The mag plug and the probable LNE spin on adapter are nice upgrades! Check your K&N filter part number and see if it cross references to a NAPA Gold 1042 filter. The NAPA Gold is the recommended filter and is what I run, then cut that filter open and inspect for debris.
Old 10-22-2016, 04:55 PM   #4
Hello Monty
How would I cut open the filter
Is there a tool I need to buy?
Old 10-22-2016, 04:56 PM   #5
filter
Thanks for the advice
Old 10-22-2016, 05:07 PM   #6
still plays with cars...
BoxsterSteve's Avatar
You can get one at Harbor Freight.
Six speed 2000 Boxster S
Old 10-22-2016, 05:13 PM   #7
FYI: the "brake sensor" is nothing more than a "U" shaped piece of wire.
When the pad wears down enough, the bare wire makes contact with the rotor, grounding the circuit and tripping the brake wear light.
They are simple to make.
Old 10-22-2016, 06:35 PM   #8
Perfectionist
I bought the Longacre Oil Filter Cutter (LA77750) which worked really well.
After cutting the filter open, you need a blade to cut the paper free from the filter.
I was using the NAPA Gold 1042 and am now using the Platinum version which NAPA claims is better for synthetic.
Shred is offline   Reply With Quote
Old 10-22-2016, 06:45 PM   #9
911monty's Avatar
Hello Monty
You can use a muffler pipe cutter from Autozone, they loan for free if you do not want to purchase a tool you'll use infrequently.
Old 10-23-2016, 04:09 AM   #10
Pipe cutter
Thanks for the tip 911Monty I will run up to Autozone and borrow the pipe cutter
