Old 10-24-2016, 12:51 PM   #11
Cranks good when start lock is bypassed, but no start?
Check for voltage at fuse D5. If no voltage, then check at current distributor fusible link F2.
I think you may have a bad connection at the current distributor firewall connection (probably on the outside, not in the cabin).
You can have good voltage at the distributor, but still have a bad connection not letting enough current through. Always clean connections.
