Old 08-29-2016, 03:13 PM   #1
Trewis15's Avatar
Send a message via Skype™ to Trewis15
Porsche Boxster 986 engine strange noise
I am from Slovakia , I do not speak English well . You know someone help me ?
I changed things marked on the photo. The sound is still not changed , it is the same .
From as many starting , I discharged battery . At the start I can fix it the same sound (in 00:15).
Trewis15 is offline   Reply With Quote
Old 08-29-2016, 03:46 PM   #2
911monty's Avatar
You might try removing the belt to see if the noise goes away with belt removed. It's ok to run a few minutes with no belt. However from that last video with the battery discharged, I would check the spark plugs. A loose plug can make a chirp like that.
Old 08-29-2016, 04:13 PM   #3
Luv2Box's Avatar
I had the same sound and 911 monty is correct it was a loose plug that had not been tightened correctly.
Luv2Box is offline   Reply With Quote
Old 08-30-2016, 01:34 PM   #4
Trewis15's Avatar
Thank you boys, I will do it. I will work with car at weekend and than I will tell you how it worked.
Old 08-30-2016, 01:42 PM   #5
911monty's Avatar
Just an FYI. New plug torque is 30nm/22ft lbs. Used plugs retorque to 25nm/19 ft lbs. Cold.
OH and Welcome!
Old 09-02-2016, 05:58 PM   #6
Trewis15's Avatar
Thank you guys very much , it was a loose spark plug. Sound stopped , everything is fine ! you are awesome
Old 09-02-2016, 08:30 PM   #7
"ragged candle" = loose spark plug ? Sorry my Slovkian is bad :-)
Pleased it is fixed for you !
Old 09-03-2016, 02:05 AM   #8
Trewis15's Avatar
Sorry, yes I fixed it. It wos loose spark plug. Google translate is bad
Old 09-03-2016, 09:13 AM   #9
911monty's Avatar
I kinda liked the "ragged candle" translation, had a chuckle over that one! Well worth the price of admission. Enjoy!
