Old 06-27-2016, 07:22 AM   #1
IronDeadPool
how do you Desnorkle ?
I ve spent all morning searching the forum on how to Desnorkle my Boxster? can someone point me in the right direction or please tell me how to do it!
Thank you in advance.
P O R S C H E . B O X S T E R
Project IronDeadPool
986ohana is offline   Reply With Quote
Old 06-27-2016, 08:23 AM   #2
Desnorkle
Not hard at all. Just did mine about two weeks ago. I will tell you that I didn't notice all that much of a difference in sound until past the 4000 to 5000 rpm range. Anyway...
1. Remove the screw at the top of the driver side intake vent.
2. Grab the vent as best you can and pull. It took quite a bit of force and some have broken their clips (there are three if I remember correctly).
3. Once the vent has been removed there may be a screen that needs to come out. Mine did not have one. If so, there may be a screw that holds it in place. Unscrew and remove.
4. With the screen out you will see the snorkel. It has a cup like scoop on the end. I wedged one of my hands inside and placed the other on top and pressed downward to dislodge the clips that hold it in.
5. Replace the screen (if you have it) and the intake vent, not forgetting the screw at the top.
Good luck!
Jgkram is offline   Reply With Quote
Old 06-27-2016, 06:08 PM   #3
Try searching "de-snorkle"
'99 black 986
Old 06-27-2016, 06:28 PM   #4
IronDeadPool
Thank you, found a lot of broken links but managed to get it done!
