Old 06-03-2016, 04:28 PM   #1
Calling Boxster Experts
So I have a new to me 1999 Boxster. The seller did tell me the engine had been rebuilt. So today I was changing the plugs and noticed the head has the number
996 104 227 3r on it. Did 5 minutes of research to discover this is a 911 head. Is that right? What do you experts purport was done during rebuild. I purchased new plug tubes to replace with the plugs and of course this head doesn't use plugs. Demystify this for me.
Jthoms1 is offline   Reply With Quote
Old 06-03-2016, 04:46 PM   #2
geraintthomas's Avatar
You mean it doesn't use plug tubes? The later boxsters didn't use plug tubes either (mine is an 03 Boxster S) so it could have been a rebuild with newer engine parts. Can you get anymore info from the seller?
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
Old 06-03-2016, 04:50 PM   #3
Correct...from what I can tell it doesn't use plug tubes. So I assumed it would have been rebuilt with newer engine parts. Does that number I provided mean anything?
Old 06-03-2016, 05:38 PM   #4
That PN is not for the head - its for the "head cover lid".
The Boxster PN's for this part are 996-based (for example, 996 104 637 5R is the part for a 2003-2004 2.7L base engine). Often 986 and 996 parts will be interchangeable between years and models.
I purport that during the rebuild someone bought a head cover lid from eBay since they are probably interchangeable and used it on your 986 engine. You'd have to actually check the head PN to know where that came from.
At this point, nothing to worry about, nothing to brag about.
Old 06-03-2016, 07:29 PM   #5
stelan's Avatar
or perhaps it was not rebuilt but swapped with a later boxster engine, is the other side also non-spark plug tube?
stelan is offline   Reply With Quote
