Old 04-10-2016, 02:51 PM   #1
rsf
Rodents...
Hello all,
I just pulled my Boxster out after having it sit for a while and thought I would do a visual inspection before taking it out for run. For the most part, everything looks good, however after looking in the engine compartment, I found something had taken up residence and made a comfy home on the top part of the engine compartment After cleaning everything out, I found a yellow wire chewed on (but not severed) and a blue and white one total chewed through.
The car starts and runs fine, everything seems to work no CEL...does anyone know what these wires do? How tough of a job would it be to replace them?...
I've attached a picture of what's left.
Any advice would be greatly appreciated.
rsf is offline   Reply With Quote
Old 04-10-2016, 02:56 PM   #2
Project Addicted
jcslocum's Avatar
Year, Model, Trans, side of engine, near what else???
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 04-10-2016, 03:11 PM   #3
rsf
It's an '03 Boxster S with a Tiptronic. Attached is a picture of where the wires are...this isn't my engine compartment, but looks close.
Old 04-10-2016, 03:40 PM   #4
I am my own mechanic....
Timco's Avatar
Please provide link to owner of car in pic so we can scold them for how dirty that thing is.
Thanks.
'08 VW Touareg T-3 wife's car
Old 04-10-2016, 04:09 PM   #5
rsf
Here's the link, honest...it's not mine.
https://www.google.com/search?q=boxster+engine+compartment&rlz=1C9BKJA_enUS592US612&hl=en-US&prmd=ivsn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwio2cLbl4XMAhUL1GMKHTt3BGAQ_AUIBygB&biw=1024&bih=653#imgrc=Jyada1WPiStn6M%3A
Old 04-11-2016, 06:36 AM   #6
2003 S, Arctic Silver, M6
paulofto's Avatar
I believe those are the wires that power the second rear fog light. Or not.
Old 04-15-2016, 04:26 PM   #7
rsf
Just checked all the lights and everything works that I can see or find.
Old 04-15-2016, 05:15 PM   #8
Porsche "Purist"
Paul's Avatar
I recommend you disconnect the battery and repair the wiring before running the car again. The blue and white wires are twisted pair so they are most likely part of the car's Canbus network. Cheap way to fix: splice them back together and seal them up with some heat shrink tubing. Tape up the yellow wire with heat resistant electrical tape.
Expensive way to fix: replace harness.
1987 924S. 2002 996TT. PST-2
Old 04-17-2016, 06:38 AM   #9
Beginner
Jamesp's Avatar
+1 really good advice. Allowing them to short may become very frustrating and expensive.
2003 S manual
Old 04-17-2016, 09:32 AM   #10
rsf
Thanks for the advice...the wires are under the throttle body / intake manifold. I've done some searching, but haven't found a good article on removing the throttle body / intake manifold to get at this area. Anyone good links or videos?
Thanks again...
Old 04-18-2016, 07:19 AM   #11
Clean the Throttle Body Porsche DIY
'99 black 986
Old 05-01-2016, 08:14 AM   #12
rsf
Started working on it today, and not as bad as I had thought. I have removed everything to get at the connector, however the brittle intake boots need to be replaced now. While I'm waiting on their arrival, does anyone know what this connector does? I've searched all over and looked a number of wiring diagrams and pictures and can't find anything. The colours on the wires are BL/BK (Blue/Black) and WT/BK (White/Black).
Old 05-01-2016, 02:53 PM   #13
stelan's Avatar
Aren't those wires going to the MAF?
stelan is offline   Reply With Quote
Old 05-01-2016, 05:52 PM   #14
rsf
No, I don't think so...the MAF is closer to the air filter box. The connector I'm showing looks like it's bolted to the block or something.
Old 05-01-2016, 06:10 PM   #15
Porsche "Purist"
Paul's Avatar
The purple arrow points to the knock sensor.
Old 05-01-2016, 06:20 PM   #16
Beginner
Jamesp's Avatar
That would be a detonation sensor. It retards timing if it senses detonation.
2003 S manual
Old 05-01-2016, 08:42 PM   #17
rsf
Since I'm this far into it, should I replace the sensor(s) proactively?...do they go bad very often? I have to order / wait for the intake boots to arrive since they deteriorated during the removal process.
