Old 03-28-2016, 10:20 AM   #1
More of a truck guy
Coolant Leak when using heater????
Yet another "Coolant Leak" question. I did some research, but nothing specific to the issue I am facing. It seems that when I drive around on non cold days (meaning I don't use the heater), my coolant level seems to stay constant and at the top of the reservoir.
However, when I use the heater, I can smell a faint whiff of coolant and after driving around a while (a couple of hours), I can see that the level in the coolant tank has dropped about 1/4"-1/2".
I am thinking heater core (which I replaced not too long ago, when there was a bad coolant smell, and I could see coolant at the bottom of the heater core housing), must circulate hot water when I activate the heater, thus maybe another leak.
I just assumed that the heater core always circulated hot water, no matter what the temp setting, but maybe I am wrong? What could be an explanation for this unique coolant loss?
2002 Boxster S 6 Speed
TNT79Bronco is offline   Reply With Quote
Old 03-28-2016, 09:20 PM   #2
9ate6's Avatar
Send a message via Yahoo to 9ate6
Check this link I found on the web Coolant smell through AC vents in 06 Boxster S
I think it's exactly the problem you described. Keep an update if it helps or not.
'97 Boxster Guards Red/Black interior, Dual Carbon Fiber Wings, 18" Zehn with Michelin Pilot Super Sport
9ate6 is offline   Reply With Quote
Old 03-29-2016, 06:23 AM   #3
Beginner
Jamesp's Avatar
You need to replace your heater core. It's an easy diy.
2003 S manual
Old 03-29-2016, 07:10 AM   #4
I thought this related to a heat exchanger. Are these terms interchangable?
