Old 02-11-2016, 08:42 AM   #1
I am my own mechanic....
Timco's Avatar
How does this happen?
Clamshell does not line up with the small piece behind the door.
'08 VW Touareg T-3 wife's car
Old 02-11-2016, 09:04 AM   #2
JayG's Avatar
Is it the same on the other side?
Old 02-11-2016, 09:21 AM   #3
stelan's Avatar
Boxster have unusual gaps in that area but perhaps not that much
stelan is offline   Reply With Quote
Old 02-11-2016, 10:10 AM   #4
CrisZenithBlue's Avatar
mine is even worse than that.
does anybody know of a way to rectify that?
CrisZenithBlue is offline   Reply With Quote
Old 02-11-2016, 10:19 AM   #5
Caulk gun?
Old 02-11-2016, 10:59 AM   #6
These cars have so much torque the chassis probably twisted
Old 02-11-2016, 11:04 AM   #7
jb92563's Avatar
Replace that part with this:
I think if you look on the underside of that part there are some adjusting bumper stops.
Perhaps they need some tweaking or have fallen off.
Old 02-11-2016, 12:00 PM   #8
BYprodriver's Avatar
Lots of wearing pivot points. Try replacing the 4 bearing sleeves where the actuators attach to the "hinges" part#99992413040
Not expensive or hard to install with top in service position.
Old 02-11-2016, 12:11 PM   #9
Twisting caused from diy lifting without a lift? I think the rubber stops are adjustable but I dont remember them working for the particular area in question. I will have to check again.
nicecar is offline   Reply With Quote
Old 02-11-2016, 11:27 AM   #10
I have basically the same problem though yours looks much better. Mine on the right pulls forward and then swings inward creating a uneven gap front to back. Left looks pretty good which is concerning.
Old 02-11-2016, 11:32 AM   #11
WillH's Avatar
That happened to mine when a top cable broke and the clam shell got twisted. As much as I tried to bend it back, I couldn't get that gap back to standard.
Old 02-11-2016, 12:27 PM   #12
JayG's Avatar
I just looked at mine it looks about the same as yours
Old 02-11-2016, 03:53 PM   #13
stelan's Avatar
I think the large gaps are there because is a design trade off, once bushings get old you rather have gaps than rubbing
Old 02-11-2016, 07:05 PM   #14
Retroman1969's Avatar
Huh. Mine is like that on the passengers side, but flush on the driver's side, on both of my cars.
They still seem to work just fine though!
Old 02-11-2016, 08:00 PM   #15
Mine is just like that, too - on both sides. It's bugged me a little bit also. I've wondered if something is bent or out of whack, or whether it's supposed to be like that. Sorry I can't help, but you're not the only one.
2001 Boxster
Old 02-12-2016, 03:46 AM   #16
PaulDash's Avatar
Check the gaps with this data from the Service Manual.
Adjust using the mounting screws on the hinges, the rubber posts, and the little plastic spacers (on the body, within the side crevices where the clamshell fits, right behind the little cover pieces).
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
Old 02-12-2016, 07:10 AM   #17
CoBeerToad's Avatar
Mine is way off too. I imagine the same thing that causes it to be off is what causes me to snap those rods constantly. I'm full manual now, but my lid is still misaligned. Maybe I'll play with it this summer.
CoBeerToad is offline   Reply With Quote
Old 02-12-2016, 05:58 PM   #18
Things Happen when you have a 15 year old car...................Oooof.
Old 02-12-2016, 10:35 PM   #19
My gaps are even all around.
You guys have broken cars. You should take care of that.
Old 02-13-2016, 06:39 PM   #20
I started investigating my gap problem today. Besides breaking the plastic piece that connects the push rod to the ball pin, I think the problem might be the bushing and spacer sleeve that connects the push rod to the lever that then goes to the clam shell. There was a lot of play there. I could definitely image the motor pulling the push rod and where there is play, it pulls a bit inward. Wonder what these parts will cost?
