Old 05-05-2006, 09:05 PM   #1
Coolant?
I need to add coolant to my car. Is there a specific brand that I need to use? I have 06 987s.
bolkar is offline   Reply With Quote
Old 05-05-2006, 09:12 PM   #2
Rail26's Avatar
I called the dealer (my closest dealer is 4 hours away) and he said anything that said lifetime on it was acceptable (prestone). I am still a little hesitant and my car needs coolant also. What say anybody else? I don't have the time right now to drive 4 hours.
5 spd, 18" wheels
AH-64 Apache
RC-12 Guardrail
RC-7 Crazy Hawk
Rail26 is offline   Reply With Quote
Old 05-06-2006, 12:22 AM   #3
What you want is a Silicate-Free coolant such as Prestone 5/150 or such. Really, any Silicate-Free coolant is compatible. Silicate-Free coolants generally are labelled as "Extended Life", and will always have the words "Silicate-Free" on the label. Be sure you use Distilled Water when you mix it up! Hope this helps...
Happy Motoring!... Jim'99
Old 05-06-2006, 11:04 AM   #4
bmussatti
Posts: n/a
OK...dumb question...how do I know if I need to add any coolant!
Bolkar, why do you need coolant already?
Old 05-06-2006, 08:55 PM   #5
Rail26's Avatar
Bmus,
Open the trunk, look at the coolant resevoir on the right hand side. There are min and max lines.
5 spd, 18" wheels
AH-64 Apache
RC-12 Guardrail
RC-7 Crazy Hawk
Old 05-07-2006, 09:05 AM   #6
That piece of plastic is almost opaq, is very hard to see the liquid behind. Finally couple days ago I got a warning to check my coolant level.
Bolkar
Old 05-07-2006, 05:00 PM   #7
if it is just a little bit low, you can add distilled water only to get it over the min level. i suggest letting the car sit over night, so the coolant goes to the lowest level. then add enough distilled water to get it over the min mark.
Finallygottaporsche is offline   Reply With Quote
