		|  10-06-2015, 04:49 AM | #1 |
	| Registered User
				Tan oil?
			I went out this morning to give Rocky an oil change and this is what came out of the engine:
The water pump has been making some noise but I haven't driven it lately.
				__________________Located in Central Mass.
 '00 Boxster
		|  10-06-2015, 05:02 AM | #2 |
	| I am my own mechanic....
			Any foam or sludge in the coolant reservoir box?
 Looks mixed with coolant. Oil cooler is first suspect.
				__________________'04 Boxster S 50 Jahre 550 Spyder Anniversary Special Edition, 851 of 1953, 6-sp, IMS/RMS, GT Metallic silver, cocoa brown leather SOLD to member Broken Linkage.
 '08 VW Touareg T-3 wife's car
		|  10-06-2015, 05:13 AM | #3 |
	| Registered User
			A little sludge in the coolant reservoir. Hoping it's the oil cooler and not that the impeller from the waterpump ate my block. Waterpump is (was) this weekends project... I had to walk away from it for a bit and calm down.
 '00 Boxster
		|  10-06-2015, 07:02 AM | #4 |
	| Registered User
			Ok now that I've calmed down some and lowered my blood pressure its time to come up with a game plan.
 I'm going to pull the water pump because its making some noise. Squeals really bad until the engine warms up and then quiets down but I do have a small leak from the bearing.
 Remove and test the oil cooler. How do I test the oil cooler?
 What else should I be testing/checking?
 Note that the coolant is in the oil and there appears to be very little oil in the coolant.
 '00 Boxster
		|  10-06-2015, 07:10 AM | #5 |
	| On the slippery slope
			In addition to finding out where the intermix is happening, you will need to do a full flush and fill of the coolant and probably the oil as well after you have it fixed
				__________________2004 Boxster S 6 speed  - DRL relay hack, Polaris AutoTop DIY
		|  10-06-2015, 09:12 AM | #6 |
	| Project Addicted
			Don't run it anymore! Your crank hates water in the bearings.....
				________________________
 Jon
 1966 912, 1976 911
 1986 944, 2000 Boxster
		|  10-06-2015, 10:02 AM | #7 |
	| Registered User
					Originally Posted by JayG  In addition to finding out where the intermix is happening, you will need to do a full flush and fill of the coolant and probably the oil as well after you have it fixed |
  To get this started pressure test the coolant system to try & locate where the coolant is entering the oil.  Since you have a 2000my good chance you have a cracked head. Now is the time to find which head before disassembling anything. When you remove the water pump you must find the missing impeller pieces!
				__________________OE engine rebuilt,3.6 litre LN Engineering billet sleeves,triple row IMSB,LN rods.  Deep sump oil pan with DT40 oil.
		|  10-06-2015, 03:03 PM | #8 |
	| Registered User
			Well that escalated quickly
		|  10-06-2015, 04:55 PM | #9 |
	| Beginner
			Yeah, cracked head is likely.  Pull your plugs, the clean, wet one is the bad actor.  Pull that head and have it welded.  Reinstall it an the drama ends.
				__________________2003 S manual
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 07:54 PM.
