Old 09-28-2015, 03:22 PM   #1
No Lights
Both my '03 S xenon headlamps are no longer working- they gradually failed to turn on after switching them on. At first they came on after a pause- sometimes a few minutes. Now nothing. My fogs come on. What's the cause- bad control unit(s)? Any other possibilities? My car only has 65000 miles - and I'd guess less than 3k with lights on. Must be an age related failure.
If it's the control units, would both need to be replaced (i.e, is each headlamp controlled by a separate control unit)? OEM replacements are $750/each (Ouch).
Where are they located- is this a DIY job?
Thanks.
Steve
MNICEBOX is offline   Reply With Quote
Old 09-28-2015, 03:55 PM   #2
On the slippery slope
JayG's Avatar
Could likely be the light switch
Do a search for cleaning it.
You can of course replace it, they run around $130
2004 996 Targa Tip
Instructor - San Diego region
Old 09-28-2015, 05:54 PM   #3
The headlight switch is the only thing that they both have in common. The chances that both headlights would fail simultaneously is slim to none.
As Jay said, clean the switch by spraying contact cleaner into it. Pelican has write up for removing the switch.
If that doesn't help or doesn't last long, you will need to replace the switch.
particlewave is online now   Reply With Quote
Old 09-28-2015, 05:56 PM   #4
JayG's Avatar
I had a problem with my headlights being intermittent in April 2014. I cleaned the switch and it has been fine since
2004 996 Targa Tip
