Old 09-14-2015, 12:09 PM   #1
squeaking noise/rattling noise
Does any one have a hint what to check for
(1) squeaking noise from left driver shoulder when roof is down.
I checked some plastic shield over roof arm which could produce it but it does not touch anything in my view;
(2) some rattling noise coming from "passenger side rear trunk" over bumps. It's not CV joint which would have more metal over metal accent. I replaced motor mount and inspected transmission mounts which don't have any thorn pieces or leaking oil. Though this is very close to worn motor mounts banging.
Both sounds are quite asymmetrical therefore I think there is some loose or worn out parts.
ftp19601960 is offline   Reply With Quote
Old 09-14-2015, 01:08 PM   #2
EJ-Fresno's Avatar
Check on the rear control arms, they tend to rattle over bumpy roads.
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 09-14-2015, 02:03 PM   #3
Rear control arms (short wide) or their links (long thin, http://www.amazon.com/TRW-98633104307-Suspension-Control-Arm/dp/B007IKMFIU)?
Old 09-14-2015, 02:27 PM   #4
99634105317?
98633104307?
Both?
Old 09-14-2015, 03:47 PM   #5
EJ-Fresno's Avatar
The long arms connecting the wheel hub to the frame (don't have the part number with me, sorry)
2006 V6 Mustang
2008 ML 350
