Old 08-27-2015, 07:49 AM   #1
Duquette5's Avatar
Dash bulbs
In my recent adventure with Rocky it has been determined that my CEL bulb has been out for sometime. Since I now have the instrument pod out I might as well change out all the bulbs. I'm leaning towards using LED's just not sure on the right twist lock size are they T8's and T5's? Has anyone done this and recall which bulb they used?
Located in Central Mass.
'00 Boxster
Duquette5 is offline   Reply With Quote
Old 08-27-2015, 08:57 PM   #2
Pdwight's Avatar
Ask particle wave...whatever he says will be right
Old 08-27-2015, 09:46 PM   #3
Well, that's kind of a trick question. The warning indicator bulbs are T5 style wedge bulbs, but the contacts are spot welded directly to the bulb, so you can't just replace the bulb. The twist locks are somewhat unique since the keyways are so narrow.
You'll also need to be sure that you get the polarity correct or you'll never know when a warning indicator comes on.
If you just want to replace the gauge cluster backlighting, www.sportscarleds.com has kits for pre-facelift clusters (this is what I used).
These may work for the warning indicators and the 3 LCDs on '97-2000 pre-facelift clusters without the larger center LCD display, like mine pictured below. The problem is the lock keyway is large, while ours are small.
http://www.ebay.com/itm/10-Twist-Lock-2-2835-SMD-T5-Instrument-Cluster-Indicator-Led-Bulbs-White-Light-/261968318158
The rotary gauges take 2 x T5's and 2 x T10's.
T10's that fit the rotary gauges.
http://www.ebay.com/itm/3X-T10-White-LED-Bulbs-with-Twist-Lock-Holders-Instrument-Gauge-Cluster-Lamp-/171904729813
May need to trim the keys on new twist locks to fit into our narrow keyways.
Old 08-28-2015, 04:32 AM   #4
Duquette5's Avatar
Thanks! I have no aversion to filing. Maybe I'll punt and order a 996 cluster Perhaps I can sneak that past the Financial Control Officer along with a new set of seats.
'00 Boxster
