Old 04-18-2006, 03:38 PM   #1
Red face Ok, new shift boot/knob, but how do I remove?
Yep, a big yank will do it.
ct_boxster is offline   Reply With Quote
Old 04-18-2006, 03:45 PM   #2
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Originally Posted by ct_boxster
I pulled, twisted, pushed? Any one? Quick answer hopefully.
Unclip the boot from the center console and it just just lift right up. Pull the boot over the shifter
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 04-18-2006, 04:23 PM   #3
I had this problem when I put a new mahogany shifter in my car.....If its been on a while, its just on tight, you may have to give it a REAL good pull, I know I had to....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 04-18-2006, 04:37 PM   #4
You may want to take a screwdriver shaft and kind of use it to jar the plastic base of the old one out of its stuck position by running the long side of it from the base of the shifter shaft upward with a little force.
I hope this makes sense. What I'm not suggesting is to pry the thing off with the tip (which won't work), but to use the upward motion of the side of the screwdriver to loosen the shifter knob from its friction fit at the top, under the knob itself.
