		|  06-26-2015, 06:04 AM | #1 |
	| 2 fast 4 U
				Cel P0410 P1411 secondary air
			I got these 2 codes after I change my AOS and cleaned out the air intake. I know these codes mean I probably have a vacuum leak. I can actually hear some hissing so I started checking all the hose and I found that this line leaks when I move it a little. Can anyone tell me what this is exactly and how hard is it to replace. It's the hose circled in red.
				__________________Drive it the way it's meant to be driven!
 2000 Boxster S
		|  06-26-2015, 07:08 AM | #2 |
	| 2 fast 4 U
			Here is another picture with the tube in question circled in red.
 2000 Boxster S
		|  06-26-2015, 08:19 AM | #3 |
	| I am my own mechanic....
			Check out Jager's thread on cleaning the exhaust ports above the main cats.
 (No, not THOSE cats......)
				__________________'04 Boxster S 50 Jahre 550 Spyder Anniversary Special Edition, 851 of 1953, 6-sp, IMS/RMS, GT Metallic silver, cocoa brown leather SOLD to member Broken Linkage.
 '08 VW Touareg T-3 wife's car
		|  06-26-2015, 09:27 AM | #4 |
	| Registered User
					Originally Posted by redeye280z  I got these 2 codes after I change my AOS and cleaned out the air intake. I know these codes mean I probably have a vacuum leak. I can actually hear some hissing so I started checking all the hose and I found that this line leaks when I move it a little. Can anyone tell me what this is exactly and how hard is it to replace. It's the hose circled in red.  |
 That hose supplys vacuum to the power brake booster.  The connecter at the intake manifold has a nylon "C" shaped shim to lock it in place, make sure it is doing it's job. There is also a small  O-ring seal at the connection secured to the intake by 2 screws.
 Your codes indicate your SAI is not effective, so if you hear the pump operating after a cold start it is not effectively leaning the AFR seen by the secondary O2 sensors.
Check the link posted by Timco.
				__________________OE engine rebuilt,3.6 litre LN Engineering billet sleeves,triple row IMSB,LN rods.  Deep sump oil pan with DT40 oil.
		|  06-26-2015, 10:19 AM | #5 |
	| 2 fast 4 U
			Jager's post on cleaning the exhaust cats was posted for code P0410. I am getting both codes  and I can hear vacuum leaking from that hose. Could a leak from that hose cause those codes?
 2000 Boxster S
		|  06-26-2015, 10:37 AM | #6 |
	| Registered User
					Originally Posted by redeye280z  Jager's post on cleaning the exhaust cats was posted for code P0410. I am getting both codes  and I can hear vacuum leaking from that hose. Could a leak from that hose cause those codes? |
 I don't see how they could be related, but obviously you don't want a vacuum leak to your brake booster so I would be fixing that 1st.
		|  06-26-2015, 02:02 PM | #7 |
	| Registered User
			If there is a leak on your brake booster vacuum line, you will feel the braking poor compared to normal....
				__________________2001 Boxster S (triple black). Sleeping easier with LN Engineering/Flat 6 IMS upgrade, low temp thermostat & underspeed pulley.
 2001 MV Agusta F4.
		|  06-26-2015, 04:09 PM | #8 |
	| 2 fast 4 U
			The leak happens when I move the hose a little. I think that the leak is very minor until you twist the hose a little. I haven't really noticed any difference in braking but I halso haven't driven it all that much since last summer. Just wondering if this leak would trigger the cel codes.
 2000 Boxster S
		|  08-15-2015, 07:05 PM | #9 |
	| 2 fast 4 U
			bump,,,,,,,,
 2000 Boxster S
		|  08-15-2015, 08:11 PM | #10 |
	| Registered User
					Originally Posted by Steve Tinker  If there is a leak on your brake booster vacuum line, you will feel the braking poor compared to normal.... |
I had a leak on that hose, but the braking wasn't affected. I think there's a check valve along the way that doesn't allow the brake booster to lose vacuum.
I tried driving the car with the hose disconnected while troubleshooting, and it took a tremendous amount of force to push that pedal down, almost impossible to stop the car without that vacuum line. Never thought it would have such an impact.
		|  08-16-2015, 02:52 AM | #11 |
	| 2 fast 4 U
			Did that leak give you any codes?
 2000 Boxster S
		|  08-16-2015, 06:54 PM | #12 |
	| Registered User
					Originally Posted by redeye280z  Did that leak give you any codes? |
Yes, P1128 and P1130, oxygen adaptation rich threshold in both banks.
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 06:05 AM.
