Old 05-06-2015, 09:13 AM   #1
Drahthaar's Avatar
Transmission Fluid
I am planning on changing the manual transmission fluid in my 03 S this weekend. I stopped by the local Porsche dealership to get some Porsche manual transmission fluid, but they said they don't sell that retail. They told me just to go pick up some Mobil 1 75/90 at any auto parts store and I would be fine. Is this the correct answer? Is there some other way to get Porsche Fluid?
Thanks!!
Drahthaar is offline   Reply With Quote
Old 05-06-2015, 09:33 AM   #2
dan.oneufer's Avatar
That is the same answer I got from my closest dealer.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
Old 05-06-2015, 09:55 AM   #3
I purchased the OEM fluid from my local dealer as recently as Jan, 2015 with no problem. The OEM fluid is Porsche PN 999.917.546.00, so they should be selling it.
Too bad you're not local or I'd say drop by and pick up some of my stock.
Old 05-06-2015, 10:02 AM   #4
Just did a quick check and its easily found online;
Porsche Porsche Boxster/986 1997-2004 Transmission oil 1 ltr. HYPOID GEBINDE
FOR PORSCHE: 99991754600, 999 917 546 00 - READY TO SHIP - (ORMD-TRANS OIL 1LTR)
Old 05-06-2015, 10:43 AM   #5
Need For Speed
KRAM36's Avatar
Cheaper here.
2003 Porsche Boxster Roadster S H6 3.2L - 99991754600 - 75W-90 Gear Oil Manual Transmission Fluid - 1 Liter - ES#1513799
2003 Boxster S
Old 05-06-2015, 11:36 AM   #6
amagalla's Avatar
$32 for 1 liter? Why does that seem insanely expensive? How many liters are needed in the 03 6 speed transmission?
Lapis Blue 03 Boxster S
Old 05-06-2015, 11:39 AM   #7
You will need 3. Something like 2.8 or something like that. There is a DIY on here, just remember to do the filler plug before the drain... You have been warned.
mump is offline   Reply With Quote
Old 05-06-2015, 11:44 AM   #8
Drahthaar's Avatar
Thanks for the help... Just ordered some Porsche OEM from ECS!
Old 05-06-2015, 02:38 PM   #9
2003 S, Arctic Silver, M6
paulofto's Avatar
If it is branded PORSCHE it is always expensive. Price out their coolant . .
PS, up here in the Great White North, the local dealer wants $48.00 a quart (946 ml). With the PCA 10% discount that is still $ 43.20
Old 05-07-2015, 11:52 PM   #10
$32 is still a good price because I paid $42 per liter before from a local dealer.
fredd5r is offline   Reply With Quote
Old 05-08-2015, 07:27 AM   #11
Chuck W.'s Avatar
$26.46 at Sunset Porsche....
ORMD-TRANS OIL 1LTR | Genuine Porsche | 999-917-546-00
1995 Porsche C4 Cab
Old 05-08-2015, 09:01 AM   #12
Need For Speed
KRAM36's Avatar
Originally Posted by Chuck W. View Post
Nice price! So is porschepartshub.com considered Sunset Porsche?
2003 Boxster S
Old 05-08-2015, 11:15 AM   #13
It is Sunset Porsche.
Old 05-08-2015, 11:30 AM   #14
I just called the local O'Reilly Auto parts and the Mobil1 75W-90 is $11.50 per quart!
Any reason we should get the Porsche one at more than twice the price?
I am thinking of changing the fluid too while the TX is out. Yes, I will remember to get the fill plug out first...
PorscheFan5 is offline   Reply With Quote
Old 05-08-2015, 11:35 AM   #15
Need For Speed
KRAM36's Avatar
Thanks. I've heard the name, but using Google search I get a Porsche dealership in Beaverton, Oregon.
2003 Boxster S
Old 05-08-2015, 12:17 PM   #16
Sunset Imports is in Beaverton Oregon. 10% over hard cost for Porsche parts if purchased from out of state. Don't walk into the parts counter though. You'll be freaked by their upcharge over retail for Pcar parts.
Old 05-08-2015, 12:41 PM   #17
98 Arctic silver 986
tommy583's Avatar
Yes it is worth it. All other gear oil will give you notchy and hard cold shifting. For as often as you have to change it it's worth the extra cost.
Old 05-08-2015, 02:35 PM   #18
+1 If you do a search you'll find several posts where using non-Porsche OEM fluid caused problems.
Old 11-16-2016, 04:26 AM   #19
To update this thread for UK owners.
I have just purchased 3 x 1 litre bottles of transmission oil from the official dealer for my 6 speed 3.2S, part no. 999.917.546.00
Price was £29.76 per litre.
Now to get on with the job, my car is a 2003 with 65K miles and no record of having been done before. Let's hope the plugs come out easily as I had a devil of the job with the brake bleed nipples.
RichRobby is offline   Reply With Quote
Old 11-17-2016, 06:38 AM   #20
paulofto's Avatar
Make sure you remove the fill plug BEFORE you remove the drain plug. Would be a problem if you drained the oil and couldn't refill it.
