Old 04-28-2015, 07:29 PM   #21
Not a whole lot to add...
Your wires will be brown with yellow stripe and red with black stripe. If they are not in the door at all, they should still be on the car side of the doors harness connector. You should be able to find them in the bundle that enters the car right above the fuse box. You would then have to run wires from the door side harness connector (assuming that they aren't there). Not an easy job.
I couldn't find a pinout for the door connector, so you'd have to probe to find the correct pins.
You can see the wires on the left side of this picture.
Old 04-28-2015, 07:48 PM   #22
I am my own mechanic....
Timco's Avatar
'08 VW Touareg T-3 wife's car
Old 04-28-2015, 08:39 PM   #23
Originally Posted by ilikeching View Post
Hi, yes power from courtesy light.
very cool looks, leds from ebay. get lots of staring when opening the door...
and i have installed front and rear trunk for better Lightning.
its an safety issue too, much more visibility when opening the door at night&day.
Do you have pictures of the trunks' lights? Where is you put the light strips?
Randy
2002 Boxster Seal Gray Metallic: Desnorkled, Changed ashtray to non-smoker's bin, Removed stickers from sunvisors, Added rear speakers, LED Shifter, Porsche logo on trunk lid, New top with heated glass window, Aspheric Driver's Side Mirror Upgrade, More to come...
randy7601 is offline   Reply With Quote
Old 04-29-2015, 02:54 AM   #24
Thanks for the info... nect chance I get (may be several days) I will take the whole door panel off and take another look....
soxfan1966 is offline   Reply With Quote
Old 05-05-2015, 04:26 PM   #25
I installed them today - was very easy once I got panel door off. thanks for the diagram.
Going to look into some door led or ghost shadow lights
Old 05-18-2019, 05:19 PM   #26
How do you replace the bulb for the door courtesy light? Do you have to remove the door panel and get it from behind, or do pop the light fixture away from the front?
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
BoxMann is offline   Reply With Quote
Old 05-18-2019, 09:11 PM   #27
The fixture just pops out of the door card.
