Old 04-13-2015, 09:01 AM   #21
Originally Posted by KenDFW View Post
Boxster 2.5/2.7 uses 8mm bolts (That's why I had to swap axles)
so which axles did you use? The 2.7 axles do not bolt up to this transmission?
Old 04-13-2015, 09:57 AM   #22
Anyone know if the Audi transmissions are offered from the factory with an LSD option?
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
Old 04-13-2015, 11:47 AM   #23
I used the 2.7 axles for the swap. The Audi transmission flange uses 10mm bolts, whereas 2.7 use 8mm. You can see in the pictures, I pulled out a flange.
KenDFW is offline   Reply With Quote
Old 04-13-2015, 11:49 AM   #24
I was actually doing research about before the swap. Some people retrofitted lsds from other Audis, and there are aftermarket companies that make lsds that fit in the a4 transmission.
cool. i ask because the torsen (similar to quaif) automatic torque biasing rear differential from a v8 audi will go into an audi 012 5-speed with just a bit of machining. apparently easily found at wreckers. the issue is that the diff will only accept audi axle flanges. apparently this is an issue for the 944 guys (they have an audi 016 in the back of their cars) put perhaps because they use 8mm axle bolts as well. otherwise a $200 solution to the $2000 limited slip issue.
That was the actual research I was doing! Ultimately, it boiled down to time as I wanted to throw the audi tranny in the car and get going.
Old 04-14-2015, 09:34 AM   #25
rp17's Avatar
Nice job Kenny.
Old 12-28-2020, 03:28 AM   #26
Hi Radium King! I have the old audi axles in my garage along with the oem bolts.
So the Boxster S uses 10x50mm bolts
The 1.8 A4 FWD axle bolts are 10x48mm 12mm triple square head bolts
So- the bolts will work and screw in.
I can take measurements of the axles. If the audi axle pattern will work with the Boxster S cv joint pattern, then this will get interesting. There are 6 holes, and the bolts will thread.
It wouldn't surprise me as Porsche and Audi share some parts!
Drudging up an old thread here. Did we ever determine if the audi axle and pattern matches the 986S?
beater986 is offline   Reply With Quote
Old 11-15-2025, 08:45 AM   #27
Originally Posted by healthservices View Post
Cool beans!
I'll have to try this the next time!
Have any more pictures of the two transmissions?
Any other things have to be swapped between the two transmisions ?
Valve bodies, connectors etc.
No codes plug and play?
Valve bodies? Those are only found in automatic transmissions. This is a manual to manual swap.
a914Freak is offline   Reply With Quote
Tags
audi , audi transmission , transmission , transmission swap
