Old 03-27-2015, 08:18 PM   #1
Lug Bolts
Hi guys
Does anyone know if these Volkswagen Lug Bolts would work on a 986? All the specs match up to those of a OEM bolt, except for the non swiveling ball seat. Does it have much effect on our car?
hancock1701 is offline   Reply With Quote
Old 03-27-2015, 10:50 PM   #2
Steve Tinker's Avatar
The swivelling collar (ball seat) is most important when using the Porsche style wheels to locate the wheel correctly and not scour into the wheel apature face.
I personally wouldn't use non swivelling bolts....
2001 MV Agusta F4.
Old 03-28-2015, 01:10 AM   #3
Need For Speed
KRAM36's Avatar
Do yourself a favor and get the proper lug bolts. Yes these cost more, but once you're holding them in your hand, you will know why.
2003 Porsche Boxster Roadster S H6 3.2L Wheels Bolts, Studs, & Nuts - PS19D28MWZNKT - Black Stock-Length Lug Bolts - Set Of 20 - ES#2598487
2003 Boxster S
Old 03-28-2015, 05:05 AM   #4
jsceash's Avatar
I've been running studs and nuts for years, put a little lube on the face. There is no ill effect. The same would apply to the fixed bolt style
Old 03-28-2015, 08:49 PM   #5
rdass623's Avatar
I have used the vw bolts as stated earlier, lubricate them and do not use a pneumatic impact, and you will be fine. you may find some minor galling on the clamped surface of the rim, but it will not cause a failure. as always, use a torque wrench when tightening your lugs.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
