Old 02-22-2015, 07:35 AM   #1
Fyeganeh's Avatar
Question 2000 Boxster MAF 125.01 - how to check if DME updated
My first post -
I have a 2.7L 2000 Boxster built in 1999. In 2004 my CEL went on and I took it to a dealership and they replaced the MAF with the 125.01 part number. The CEL went on within 3 months and they replaced it again with a 125.01. Since then no more MAF problems.
I was reading through 986forum and found out the the early 2000 cars should have the 124.00 MAF or need their DME updated if they have a 125.01 installed. My receipt from the dealership did not mention that an update to the DME was done. Based on the info from the Porsche Tech note on VINs that need the 124.00, I believe mine should have had the 124.00. My VIN is 985YU622841
So my question is how can I find out if the DME has been updated to the proper version? The dealership went out of business... I have noticed a lag when I press the gas after being steady at around 3000 rpm and thought this may due to the wrong MAF.
I do have the novice durametric software and it says I have DME 7.2, type ID DME control unit 986US04, data version 0041570264503413.
Thanks for any help!
Fred
Fyeganeh is offline   Reply With Quote
Old 02-22-2015, 09:08 AM   #2
Originally Posted by Fyeganeh View Post
My first post -
Fred
The easiest way is how the car is running; if they didn't update the software, and use the newer MAF, it would not run very well.
Old 02-22-2015, 09:21 AM   #3
Fyeganeh's Avatar
Thanks for the reply. It doesn't run bad, but I'm not sure that it runs as well as it could.
The reason for saying that is that last fall, I had a lot of work done on the car to replace the IMSB, clutch, RMS, AOS, 2 chains, chain tensioners, and chain wear pads - all preventive maintenance. When I got it back, the car initially was running with a noticeable increase in power. But after a while that extra power is no longer there. My understanding is that everything got reset with the battery disconnect and the car DME had to relearn the settings.
Also I notice a lag in response when I hit the gas when I'm driving at a steady about 3200-3600 rpm.
Both of these could just be the way a Boxster is supposed to handle, but I don't know whether it is related to an incorrect MAF being installed.
So how bad would it run with the wrong MAF? Would it stall, put up a CEL, or other noticeable symptoms, or it would just be less power and less responsiveness?
Old 02-22-2015, 10:08 AM   #4
With the incorrect MAF flash, the car would idle poorly, stumble, and be unresponsive.
Old 02-22-2015, 11:04 AM   #5
Fyeganeh's Avatar
Well I don't think it idles poorly or stumbles, but its responsiveness I guess could be better.
My hope was that someone would know a resource that would have the updated DME software version number. My understanding is that my version of the software is 004157026450 with update 3413 from the Durametric reading. I guess only Porsche has the actual version numbers and would know whether mine has been updated properly.
I'm thinking of buying a used MAF with part number 996.606.124.00 and putting it in and seeing whether it runs any better than the 125.01 that I have in now.
Old 02-22-2015, 11:31 AM   #6
BIGJake111's Avatar
Bought a 124 part today for my 2000S with the last 4 in the vin being 0827, im hoping I got the right part.
Old 02-22-2015, 12:51 PM   #7
Fyeganeh's Avatar
Here is the pelican parts link for installing and picking the right part:
Pelican Technical Article: Troubleshooting and Replacing the Boxster Mass Air Flow Sensor (MAF) - 986 / 987
Old 02-22-2015, 04:25 PM   #8
Rennzenn
j.fro's Avatar
I've had MAF issues that could be 124/125.01/ECU related. My car was running with the 125.01 after the change and "update" (shop didn't get it right). During a Dyno test I discovered it was running lean. Chased the lean condition for years, and when I went back to a 124 the lean condition was resolved and the car ran much better.
Use your Durametric to check your pre-cat O2 sensor voltages. They should average 0.45, going up and down a bit. If they sit at 0.1 or less, you're lean.
Rennzenn
Jfro@rennzenn.com
Old 02-22-2015, 05:37 PM   #9
Fyeganeh's Avatar
I tried it and got a sigmoid curve that probably averages around 0.45. Is this what it is supposed to look like?
Old 02-23-2015, 03:46 PM   #10
Rennzenn
j.fro's Avatar
Yup, that looks good.
Rennzenn
Jfro@rennzenn.com
