Old 02-11-2015, 04:24 AM   #1
thom4782's Avatar
Replacing Variocam Pads - How much Improvement
Today, I'm having the variocam pads replaced on both banks because the cam shaft deviations are out of spec.
What should I expect in terms of improvement.
For example, if they are -6.5 now, should I expect something close to 0 after the new pads are installed?
Old 02-11-2015, 04:37 AM   #2
steved0x's Avatar
I think you may also notice some increases in MPG and possibly power as well. Somebody did those pads themselves on here and was able to get it close to 0, and with a performance increase too if I remember correctly. I will try to find the thread.
Old 02-11-2015, 06:10 AM   #3
Artist, 986S tinkerer
NewArt's Avatar
-6.5 is only slightly out of spec. Pads are essentially a maintenance item which will bring you closer to zero but don't expect any noticeable changes. Inspect your old pads when they are removed. Big ruts and/or chips? I went from 9 and 6 to about 3 when I changed my pads, but I only did the top ones.
Old 02-11-2015, 07:37 AM   #4
BYprodriver's Avatar
Depends on how badly the old pads are worn.
Old 02-11-2015, 07:55 AM   #5
Vario-cam pads.
"What should I expect in terms of improvement. ?"
The risk of broken pieces of plastic pads in the oil system is a significant issue.
If you get only a slight improvement on the cam deviation - suspect other parts -for example the actuator unit/solenoid, 4&5 chain wear and theoretically IMSB.
A useful related question is what else to do while the cam covers are off ?
Old 02-11-2015, 08:10 AM   #6
Model year? Miles?
Old 02-11-2015, 11:15 AM   #7
thom4782's Avatar
01S, 125000 miles; deviation values have been increasing by about 1 degree per year for the last four years
