Old 10-14-2014, 06:00 AM   #1
todds99's Avatar
1999 Boxster slips going into 5th tiptronic
Hi i just bought a 99 Boxster and was getting on the interstate and i had it in Drive.I was in forth as it shifted to 5th it reved up about another grand before it grabed.It has just had the trans rebuilt with a new torque converter.Any thoughts would be great thanks.
todds99 is offline   Reply With Quote
Old 10-14-2014, 06:49 AM   #2
JayG's Avatar
Take it back to the shop that did the work
Old 10-14-2014, 08:41 AM   #3
Artist, 986S tinkerer
NewArt's Avatar
Fluid levels should be checked again. I topped mine up 3 times before all the nooks and crannies were filled!
Old 10-14-2014, 02:33 PM   #4
todds99's Avatar
How do i check the trans fluid?
Old 10-14-2014, 06:07 PM   #5
The reason it's not in the owner's manual is that checking Tip fluid level is a relatively complicated procedure, done from under the car. If you're keen on doing this sort of thing yourself, I recommend you buy the Bentley manual.
Old 10-14-2014, 06:46 PM   #6
Tucker2's Avatar
2nd that. And random words to make this long enough to post. Grr.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 10-14-2014, 06:52 PM   #7
todds99's Avatar
The problem is the previous owner had the work done and that was 13 months ago according to the paperwork.It's my deal now..
Old 10-14-2014, 07:18 PM   #8
NewArt's Avatar
1. Car on jackstands
2. Run car until trans temp reaches 100 degrees F. using infra red temp tool
3. Remove filler plug with car running
4. Pump in ATF 1 with hooked filler tube until fluid overflows out the hole
5. Close plug and turn off car
6. Road test
7. Repeat if necessary after ATF has cooled down to 100 F.
It's a messy job. Temperature is important. You can make the filler out of a modified garden sprayer.
Old 10-14-2014, 07:24 PM   #9
todds99's Avatar
6. Road test
I got it.Thanks for your help.
Old 10-15-2014, 11:50 PM   #10
Nine8Six's Avatar
Todd
Also had this slipping 5th thing a while ago. There is a vacuum valve that triggers open/close for the cooling of the tip. Located on the driver side right next to the tip/shift rod. This valve was shot (seized) on my car and after my indy here replaced it for a new one ($125) the slipping 5th instantly stopped.
Yours might also be overheating like mine was but as the other fellas here recommended, it's worth ruling out low ATF also
luck mate
Old 10-16-2014, 05:59 AM   #11
Xpit77's Avatar
Are you lifting off of the throttle when you change then picking it up hard as soon as you hit the switch ? Does it do it in other gear changes ? Mine was a bit slow but it didn`t jump a grand though. I had it serviced, fluids and a filter and its much faster changing now. Can you smell burnt trans fluid ?
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 10-16-2014, 02:44 PM   #12
todds99's Avatar
Thanks for all the help guy's it has only happened once.It just had me a little concerned.Looking at the paperwork the trans fluid and rebuild was performed 14 grand ago.This weekend i will check the fluid.Should it be changed?Can the fluid be bought locally and what type?Im waiting on my manuals..I will also check that vacum valve.
