Old 09-19-2014, 05:49 AM   #1
Unhappy Starting and stalling issues
I have a '97 2.5l boxster with around 117k miles on it. Bought it mid June and am now it's third owner. Love the car and it runs great so far except for one incident. Drove it out to the bar had a drink came back out to drive home and couldn't get it to start. It would turn over and start for a quick second but I would through it in gear and it would die again. Seem to be a fuel issue to me most likely my fuel pump going bad. I had over half a tank but I decided to throw some gas in since all my other tricks didn't work. Started and ran after a few tries and I was able to get it home. It drove okay not as good as normal and my idle seemed to be a little eradict jumping around 700-900 rpms. At the higher rpm range it still ran great. I've made a checklist of stuff to do this weekend before I go out buying a new fuel pump and sender unit. My question is there anything else I should add/check or any other possibilities of what could be wrong with her. Thanks for any input!
Porsche Checklist:
Replace fuel filter
Test the fuel pump electronics
Clean throttle body
Clean mass air flow sensor
Replace battery
Get engine codes ran
Inspect crank sensor
Run sea foam injector cleaner
Check immobolizer under seat for water damage
Check for possible water in gas tank
Check spark
Check air pump system
Variocam actuator check
jwatson is offline   Reply With Quote
Old 09-19-2014, 06:12 AM   #2
JayG's Avatar
You have the optional PAD safety cutout.
Porsche Alcohol Detector. It detects alcohol in your system and won't let the car run.
All seriousness aside. It looks like you have done some searching and came up with a good list of things to check.
Old 09-19-2014, 06:43 AM   #3
Haha how do you bypass said PAD?
Old 09-19-2014, 03:31 PM   #4
I am my own mechanic....
Timco's Avatar
If not done recent, do plugs, check coil packs.
Not sure if sea foam is advised to run.
'08 VW Touareg T-3 wife's car
Old 09-19-2014, 03:53 PM   #5
BYprodriver's Avatar
Good list there. Good chance fuel filter needs to be changed. It's under the front underbody panel so it gets forgotten easily. You can test fuel pressure at the fuel rail using the schraeder valve there.
Old 09-19-2014, 04:21 PM   #6
Jager's Avatar
Why are you buying a sender unit? Gauge not reading correctly?
Jäger
300K Mile Club
Old 09-19-2014, 04:46 PM   #7
Porsche "Purist"
Paul's Avatar
Read the codes before doing anything more. Some codes do not light the CEL. Checking the variocam on a 2.5?
1987 924S. 2002 996TT. PST-2
Old 09-20-2014, 12:32 AM   #8
Just had the same issue with my 00' 2.7
Been running fine, stopped for coffee and now wouldn't start. Had to wait about 20 mins and then started and been running fine since.
Well since yesterday when it do it again!!
I have heard it could be the fuel sender valve?
No expert so any advice welcome
Dext986 is offline   Reply With Quote
Old 09-20-2014, 07:58 PM   #9
Replaced the fuel and air filter, pulled the throttle body and let it soak in carb cleaner overnight, cleaned all the plenum boots, tighten all the clamps, cleaned all the sensors, and put in injector cleaner. Turned it over and it struggled a little bit then it kicked on there was a distinct pop sound and then she started running fine. My idle held steady at 900 rpms no more weird smell. I did notice after the fan kicked off I can hear a slight hissing noise I noticed it before but never payed much attention (especially since I don't take the engine cover off often and it's not noticeable with it on). Anybody know if this is a fairly normal sound or do I have some kind of vacuum leak?
Old 09-24-2014, 02:54 AM   #10
Guvs's Avatar
Thanks for the up date, it's nice to know the outcome of a problem not just hearing about the problem, and if it's running fine don't worry to much about a slight hissing noise unless it gets worse.
Guvs
Guvs is offline   Reply With Quote
Old 09-26-2014, 04:50 PM   #11
Mine has Same symptoms
Curious if you figured it out?
I cleaned my MAF and it helped once, but not the second time.
Thanks.
John
theboogins is offline   Reply With Quote
