Old 04-21-2014, 09:07 AM   #1
Tiptronic wontwont go into gear
Im helping somebody out who just replaced his tiptronic transmission and now the new one wont go into any gear. The shifter is working, but it wont actually engage in gear. Just does nothing. The only thing I can think of is the torque converter was installed incorrectly. Fluid level and filter have been checked.
Is there a way to check pressure with the trans in the car?
j911brick is offline   Reply With Quote
Old 04-22-2014, 11:46 PM   #2
Turns out the torque converter was actually installed incorrectly and broke the tabs on the pump drive gear. Only solution is (another) transmission.
Old 04-22-2014, 11:58 PM   #3
Nine8Six's Avatar
No way. Can't believe you can't get it rebuild by anyone? Nobody knows about the tip where you are? I'd check with a few Pcar indy in your location before going with the full replacement option
Old 04-23-2014, 09:45 AM   #4
Registered Boxster abuser
healthservices's Avatar
Front pumps can be replaced and the tranny parts are fairly common as they are shared with the Mercedes and Audi. The problem is you have to remove everything inside the trans to get to the pump assembly
Old 04-23-2014, 11:09 AM   #5
Torque Converter - 986 Series (Boxster, Boxster S) - RennTech.org Forums
Project 5HP19 Transmission: Oil Pump and C clutch - E46Fanatics
2001 Lapis Blue Boxster S Tip (stock), 2001 Guards Red Boxster 5-speed (not very stock)
tightbox is offline   Reply With Quote
Old 04-23-2014, 02:38 PM   #6
No local indi shop will touch it and the cost of a rebuild exceeds just buying a another used one by a long shot.
Old 04-23-2014, 02:40 PM   #7
That is what I hear and I don't know if I want to go down that road on somebody eles' car which I will be responsible for. I would rather he buy another trans and if it doesn't work its on him.
Old 04-23-2014, 03:03 PM   #8
THanks for the tip. Lots of good information.
