Old 04-09-2014, 05:53 PM   #1
Jager's Avatar
P1689 Control Unit Faulty
Has anyone seen a P1689 error code? My friend has a 97 Boxster with CEL, so we connected to my Durametric and here is what displayed:
P1126 O2 Sensor (4-6)
P1124 O2 Sensor (1-3)
P0102 Mass Air Flow Sensor Short Circuit/Open Circuit
The motor is running great with 60,000 miles on the clock. I did a search on this forum with this error code but not much found for this alarm.
Edit... I will add that the voltage on the pre-catalytic converter O2 sensors are flat on both banks (0 volts)
Jäger
300K Mile Club
Old 04-10-2014, 09:47 AM   #2
BYprodriver's Avatar
Jager, my Service manual says P1689 Engine control module faulty. If such faults occur, replace the ECM. No more info in the oem manual.
Old 04-10-2014, 03:59 PM   #3
I guess I would start by seeing if there is voltage in the harness going to the O2 sensors. If not, it could be the ECU is dead. Is there a fuse or relay for the ECU? What do the voltage graphs look like for the sensors, before and after cats? The befores should look like a sine wave and the afters should be pretty close to a straight line.
Then, I would swap out the MAF with a known one to see if its good. There are also a couple of diagnostics for the MAF on the duramteric, voltage, I believe and maybe resistance.
Do the MAF values vary at all upon acceleration?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
