Old 04-06-2014, 11:16 PM   #1
Beelzy's Avatar
Oil filter removal...can it be done without full oil change?
Can one remove the oil filter between oil changes for inspection without
losing a lot of oil, and avoid a complete oil change service?
Thanks!
Beelzy is offline   Reply With Quote
Old 04-06-2014, 11:32 PM   #2
I'm pretty sure you can. I overfilled my car with oil from the last oil change, and I removed the filter to drain about more than half a quart. So yes!
hancock1701 is offline   Reply With Quote
Old 04-07-2014, 12:06 AM   #3
RawleyD's Avatar
The answer is yes,
:ah:
Old 04-07-2014, 12:48 AM   #4
DennisAN's Avatar
I bought my 986 in early February and have already changed the filter twice for inspection. You barely even get your hands dirty. You need to replenish the oil in the housing if you discard it, which I did.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
Old 04-07-2014, 06:09 AM   #5
Yes, the oil filter is higher than the sump so the only oil you'll lose is what remains in the filter housing (<1qt).
