Old 03-28-2014, 12:12 PM   #1
Coaster's Avatar
Windscreen and toll road speeds
New owner here, just got my 03 S a few weeks ago. I spend a lot of time on a toll road at 80 (ish) mph. With the top down, I can see the glass windscreen rattle quite a bit at these highway speeds. Is there a recommended top speed with top down and wind screen in place. I'm slightly concerned it will pop out. Does it need to be seated better, new clips, just taken off at those speeds?
Coaster is offline   Reply With Quote
Old 03-28-2014, 01:15 PM   #2
BIGJake111's Avatar
+1 on this, i am very curious myself as when on the interstate with the top down the wind reflector rattles alot.
Old 03-28-2014, 01:23 PM   #3
You can buy replacement clips, and you should. That's 99% of the rattle problem.
For the other 1%, I put some thin foam tape along the bottom of the plastic windscreen so it sits a tad higher in the groove and it doesn't rattle any more. Give that a try.
Be very careful removing your windscreen... if the frame bits snap off, the thing is toast.
Old 03-28-2014, 01:30 PM   #4
Cool
Just yesterday I put my deflector back on after being off all Winter long.......I noticed that the left side was loose in the fitting, so I used 2 small pieces of tape on the fitting (cant see the tape with the deflector in place) and it seems very snug now. Its raining here in Atlanta so I can test to see if still rattles, but it should be better.
nobrakes is offline   Reply With Quote
Old 03-28-2014, 01:33 PM   #5
Does anybody actually notice a difference with the deflector?.........
Old 03-28-2014, 02:07 PM   #6
OKCShooter's Avatar
Not for me.
OKCShooter is offline   Reply With Quote
Old 03-28-2014, 02:18 PM   #7
BruceH's Avatar
Yes, plus I added the plexiglass inserts for the roll bars, makes a big difference IMO.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 03-28-2014, 04:26 PM   #8
rp17's Avatar
I've heard of windscreens flying off on Boxsters before. I've done some serious speeds with the top down with no problem though. But as these cars get older, take precaustions. Soft side of a velcro strip can silence a noisy windscreen also. I like the idea of buying the new clips. Are they priced reasonablly? (not trick question)
Old 03-28-2014, 05:29 PM   #9
Coaster's Avatar
Thx, I just bought new clips for $11 plus shipping (along with a few other bits). Hopefully they are a snap to swap out. Used suncoast parts.
Old 03-29-2014, 07:30 AM   #10
I've had my Box with top down at over 100mph doing fun laps at Road America, without issue. The windscreen does make a difference in buffeting and stayed in place, also without rattle. I did discreetly cable tie the mesh headrest backs to the roll hoops, as I've heard of them flying off at speed.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 03-29-2014, 07:52 AM   #11
Carlisabadman986's Avatar
Do you have a link to said clips?
My deflector rattles at speed as well. Both of the mesh headrest back were broken at time of purchase. I might look into getting those replaced one day.
Carlisabadman986 is offline   Reply With Quote
Old 03-29-2014, 07:57 AM   #12
I was just on the pelican web site. Here is a link to the clips, etc.
Porsche Boxster Interior Accessories - Page 5
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 03-29-2014, 01:22 PM   #13
edc
550 Anniversary
edc's Avatar
I did 147mph GPS verified top down exiting a tunnel in Italy before the proximity of lots of trucks in the lane next to me made me think I should slow down
If you can hear the wind deflector at these speeds then you have much more acute hearing than I do!
Old 03-29-2014, 02:15 PM   #14
kk2002s's Avatar
Have done 100 mine rattle I use fuzzy side of Velcro tape
I also zip tie the bottoms in case they come lose
Seal Grey
Old 03-29-2014, 02:41 PM   #15
schnellman's Avatar
I've hit triple digits with no effect on either the plexiglass or the headrest inserts. I have no velcro, and no zip ties. I do believe the plexiglass prevents some buffeting.
Old 03-29-2014, 02:45 PM   #16
Almost every day in the summer, triple digits, no problems for the past 3 years. I do buy new clips yearly just to cut down on the rattle.
mump is offline   Reply With Quote
Old 03-29-2014, 07:53 PM   #17
Atomicblue99's Avatar
Mine rattled when I got the car last year. I went to a craft store and got a 25 cent piece of felt, cut it to fit into the contact points and use spray adhesive I already had to secure it. It quieted down the wind deflector quite a bit.
Atomicblue99 is offline   Reply With Quote
Old 03-29-2014, 09:43 PM   #18
I don't see the clips in the link above. Can someone direct me in the right direction.
818BoxsterS is offline   Reply With Quote
Old 03-29-2014, 10:40 PM   #19
Here are the part numbers. About $10 for the set. I had my local dealer order them along with a few other misc parts.
9865617370101C
9865617380101C
teleski is offline   Reply With Quote
Old 03-30-2014, 01:55 PM   #20
doragman's Avatar
same here...works
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
