Old 03-15-2014, 01:45 AM   #1
tomc88's Avatar
horn beeps twice when unlocking
my boxster horn beeps twice when unlocking
I know if beeps when you Lock then something's open,
but what about the double horn when unlocking?!
any ideas what would cause that?
2001 Boxster S
tomc88 is offline   Reply With Quote
Old 03-15-2014, 02:52 AM   #2
Normal I believe. Double beep on lock is cause for concern but unlock is normal.
Old 03-15-2014, 04:48 AM   #3
tonycarreon's Avatar
i've seen this posted a few times, and so far i don't know if anyone has figured out what is happening. i can tell you my 2001 does NOT beep when unlocking. only when locking and something is wrong.
Old 03-15-2014, 04:54 AM   #4
kjc2050's Avatar
Same here with my 2000 S.
Old 03-15-2014, 04:54 AM   #5
Beginner
Jamesp's Avatar
My box does not beep at all and I wish it would. Is this programmable?
2003 S manual
Old 03-15-2014, 06:10 AM   #6
tomc88's Avatar
no this is not normal.
it's something that has only started to happen recently, in the last couple of weeks.
owned the car 8 months.
and, it's not consistent, does most of the time now, but not all.
2001 Boxster S
Old 03-15-2014, 09:14 AM   #7
thom4782's Avatar
A double beep means there is a fault in the locking system. It could something as simple as a defective position sensor in a door lock. You will need to read out the fault codes. A Durametric can do this. In my case, the codes pointed me in the right direction, but didn't reveal the exact broken part.
