Old 02-13-2006, 08:04 AM   #1
Originally Posted by bmussatti
60-60 works pretty well for....Cabernet Sauvignon!
There have been some excellent post here from MNBoxster on Winter Storage...and he should know, he lives up in Minneapolis/St. Paul.
It sounds like you have a climate controlled area for storage. Is this right? With energy costs the way they are, storing at 60 degrees is going to be expensive. Anything above freezing would be good for the fluids. Does the car really care if it is 40 degrees or 60? I don't think so.
60% Humidity sounds kind of high.
Yes have a seperate 4 bay Garage AKA (Man Land ) per my wife. Have heat and a/c , Cable no couch though. I am storing the other summer only cars in there as well. The real debate is the humidty and not so much the temp. The temp is more important to me as I like to go and tinker and hate to wait for the garage to warm up from 40 - 60. Plus the temperature changing seems to cause condensation which i'm trying to stay away from. The camaro is a numbers matching (1997 frame off resto) only 2,000 miles (Hoping to put on Barrett jackson one day and get enough coin to buy a GT3, LOL) my debate with dohdoh (my buddy) is that you need some humidity for the rubber, Leather ect. I hope jim Responds as I know his weather must be close if not worse than ours(Sorry jim).
Badboy S
2000 Porsche Box S arctic silver
2007 Sierra Crew Cab Z71
1995 Honda Civic *Track Toy*
1971 Olds Cutlass Convertible
1968 Camaro SS 396 4 speed
2000 V Star 1100
BadBoyS is offline   Reply With Quote
Old 02-13-2006, 10:30 AM   #2
bmussatti
Guest
Posts: n/a
I am thinking 35% humidity would be good. You don't keep your house (approx. 72 degrees) at 60% humidity this time of the year...do you?
Old 02-13-2006, 10:43 AM   #3
Hi,
The Dryer, the Better. Moisture (Humidity) is Not Good for Rubber Parts - promotes the growth of Mildew (Dry Rot - invisible kind which actually Eats Rubber, often seen as a white powdery substance). This is why many Long-Term Storage facilities use a sealed Nitrogen Atmoshere (Plus there's no OČ to Oxidize anything) and also many Museums and Long-Term Stored Cars use Nitrogen in the Tires - to prohibit Moisture accumulation and thereby reducing/eliminating Dry Rot. Also, Dry is best for Leather as well. Get your Man Land as Dry as possible. Hope this helps...
Happy Motoring!... Jim'99
Old 02-13-2006, 11:54 AM   #4
Thanks .... Sometimes I think the wife has the house at 75 (Bmussatti) !!! 68-70 when I'm home I'll have to check the Humidity in the house Not really Sure i know it doesn't feel like florida Thanks Mnboxster now I'm out a double Cheeseburger Really good info I will kick up the dehumidier!!!! Not sure I'm going to put the Nitrogen in the tires .. I'll just do the yearly air change though. LOL
Badboy S
2000 V Star 1100
Old 02-13-2006, 12:41 PM   #5
bmussatti
Guest
Posts: n/a
Many of the big tire store chains do the nitrogen fill. Cost about $20. Costco does it too. FYI.
Old 02-13-2006, 09:04 PM   #6
If humidity is a problem use this...
http://www.madvet.com/shop?frame=1.546
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 02-14-2006, 08:17 AM   #7
bmussatti
Guest
Posts: n/a
Adam, good link! Thanks. Have you used these? If so, how long do they last??
Old 02-26-2006, 11:04 AM   #8
These look neat but to regenerate you have to put in oven for 6 hours. That seems like a PIA and they don't recommend the old Micowave.. Nice product maybe I can time it right when the wife has the turkey in the oven for 8 hours on thanksgiving (LOL)
Badboy S
2000 V Star 1100
