Old 01-24-2014, 07:53 PM   #21
I had a rock chipped front bumper repainted last year....under $400.
I should have replaced my water pump while I was at it.
Sorry, just had to.
Old 01-24-2014, 09:07 PM   #22
I am my own mechanic....
Timco's Avatar
Did you soap the gas fitting joints to check for leaks?
Wonder what the combustion numbers (CO output) are more importantly.....they are altitude sensitive......
'08 VW Touareg T-3 wife's car
Old 01-24-2014, 09:32 PM   #23
jb92563's Avatar
It is possible to do a great DIY job if you buy good equipment and practice first.
I resprayed an airplane in my garage. Turned out really nice except for a run that developed on an underside of the fuselage.
I spent $450 for a decent HVLP sprayer and another $400 for the presurized suit fresh air suppy.
Built a plastic tent inside the garage and it worked out alright. I practiced quite a bit though beforehand.
I saved myself about $8000 and now have equipment for my next project
Old 01-25-2014, 08:19 AM   #24
Didn't read entire thead so sorry if this is repeated info. I I work at a body shop. Saw someone say something about 80-100 bucks an hour and for labor..... Most shops are 42-50 an hour. 85-100 are mechanical rates. That job is tops 500 bucks . That damage is so minimal it would take a tech 20 mins to have that thing to the painters. Also saw something about having to paint the whole bumper for a clean job.... Again not true. Blending out the color and full clear is all that is needed.
2001 Boxster S - Triple Black -
Billy Boat Muffler
ROW M030 Suspension
LNE IMSB
PorscheBound is offline   Reply With Quote
Old 04-10-2014, 05:59 PM   #25
The cracks went all the way through the base coat.
After wet sanding past some of the chips and cracks...
I've already done several coats and smoothed everything out, but don't have a picture because it's dark out. Blending, clear and polish tomorrow
Old 04-10-2014, 07:47 PM   #26
epapp's Avatar
Shehadehd should follow your steps in this thread. He's got some dirty secrets of his own
epapp is offline   Reply With Quote
Old 04-10-2014, 08:26 PM   #27
The lighting in this picture sucks, but this is after a couple coats and some wet sanding.
Still a way to go on base coat smoothing, but getting there
Old 04-11-2014, 09:31 PM   #28
I still have a little way to go, but it looks like it's going to blend nicely
Old 04-12-2014, 02:30 PM   #29
Beginner
Jamesp's Avatar
Looking good. You'll want to get the masking tape off quickly as it will "become one" with whatever it is stuck to. I like the blue painters tape as it is less sticky over the long term.
2003 S manual
Old 04-12-2014, 02:56 PM   #30
Nine8Six's Avatar
a million time better looking than it was before the touch up Charles. Nice move!
I'm guessing you'll need to buff the fresh paint with a buffing wheel of some sort to even the paint with the old? how does that work
Old 04-25-2014, 02:38 PM   #31
I know what you mean...however, I despise blue painters tape as it can actually bleed blue into your paint and it doesn't hold for crud (it always, ALWAYS lets paint bleed under itself when I've tried to use it). This stuff was constantly getting wet, so had just enough hold.
I sanded the clear coat off extending out about 1/2 meter on each side of the repair. I then carefully feathered and blended the base coat with the repair.
The old clear was feathered at the edges and new clear blended over top, extending about 10-15 cm over the old clear. This left some clear "speckling" from the oversparay that is then buffed and blended in with the old.
It could have been done better by a pro, but for $30 worth of paint and clearcoat, I'm happy with it for now.
Naysayers say what?!
Yeah, I got some paint on my bumperettes and on my potato, but it scrubs off easy.
I think I'll paint the bumperettes next
Old 04-25-2014, 04:15 PM   #32
BruceH's Avatar
Nicely done Charles
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 04-25-2014, 04:20 PM   #33
Lookin good buddy. I could use a respray on my bumpers too. Spring project number 1003. lol
markskyline is offline   Reply With Quote
Old 04-25-2014, 04:35 PM   #34
Fantastic job!
Also, I love the use of the potato to hid the license plate
cardiffgiant is offline   Reply With Quote
Old 04-25-2014, 07:17 PM   #35
Looks fantastic! Well done my friend.
2000 Boxster S - B.A.D. short shifter and intake plenum - 996 throttle body - Fred's xenon projector headlights - blue LED instrument cluster - and a few other things
Driving this car makes me wish I lived farther away from work!
Troy.Boxster is offline   Reply With Quote
Old 04-26-2014, 12:01 AM   #36
Nine8Six's Avatar
wow.... just like that huh. Nicely done Charles, can't tell
(hrrrr you and your potatoes lol)
