01-11-2014, 06:32 PM
cleaned my radiators
I finally bit the bullet and cleaned the radiators. Glad I did it. Dead bird on the front side and lots of trash built up in between.
01-11-2014, 06:44 PM
Rennzenn
Dead bird, wow! Best I ever got was a mummified frog.
01-11-2014, 08:57 PM
Road kill counts. Ten points for you.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
01-11-2014, 10:43 PM
Man....it's gross, right? Yeeesh.
Current: 981 Cayman
Former: '02 BS and '08 C
01-12-2014, 02:28 PM
Yep. The radiators smelled like dead animal. for sure
01-12-2014, 07:06 PM
did you pull the front bumper cover? Was it a hard job? Doesn't look to complicated in the write ups, and I will do this job soon.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
01-12-2014, 07:16 PM
There Is No Substitute.
You have to remove the front bumper. It's not hard, but it does take a few hours. I did this when I added LED DRL's and an air horn. Never found anything as interesting as a bird though!
01-12-2014, 08:11 PM
I took my time. Probably took 2 hours for the entire job. Took about 30 minutes to remove the bumper. Hardest part was the behind the fender liner. I watch a 5 minute video on youtube. that REALLY helped.
01-13-2014, 10:47 AM
Originally Posted by jdlmodelt
...I watch a 5 minute video on youtube. that REALLY helped.
linky?....
Ed
Pittsburgh, PA
01-18-2014, 02:03 PM
Radiator cleaning
Another alternative to removing the front bumper assembly is to buy some dishwasher hose or other flexible hose. Get about three feet and make sure it is sufficiently sturdy that a vacuum cleaner won't collapse it. I attached the dishwasher hose to a shop vac and push through the air slats on the front bumper. You may want to put a little painters tape on the bumper so it won't scratch the paint. You can then maneuver the hose around and get a lot of accumulated leaves, etc from the radiator. This is not as thorough as removing the bumper, but it is quick and easy.
01-18-2014, 09:43 PM
Thanks for reposting -- I noticed some needle movement on hot days last summer -- on my agenda for Feb
'99 986 Baton Rouge, LA
09-13-2014, 12:17 PM
Thank you.
09-13-2014, 03:30 PM
Good tip but if you or a shop haven't removed the bumper in a while, go through the whole procedure and separate the radiators. You will be amazed whats in there.
09-13-2014, 03:42 PM
Did mine last weeknd.
09-13-2014, 04:49 PM
I don't know if it is just me, or if others have this happen to them.
After cleaning out the radiators, do you cringe when you see leaves swirling on the road in front of you? You just know that they are going to get sucked into the grill and clog up the radiators again.
09-13-2014, 08:49 PM
That's why I did it today before I put on my new grill guards.
Before:
After:
09-14-2014, 02:31 PM
Frustration= Putting the very last bolt in as you reinstall your front bumper back on with the new grill guards and you realize you forgot to put the temp sensor back through the holder.
AAGGGHHHHHH!!!
09-14-2014, 05:13 PM
What grill guards did you put in, got a pic or link?
09-15-2014, 04:44 AM
