Old 01-11-2014, 12:19 PM   #1
I am my own mechanic....
Timco's Avatar
Ford Ranger push rod V6 idle all over!
My workhorse is a Ranger. Pushrod 6 3.0.
Idle sticks at like 3k sometimes, drops, then climbs! Peddal all the way up.
What would cause something like this? No error codes.
'08 VW Touareg T-3 wife's car
Old 01-11-2014, 12:24 PM   #2
Nine8Six's Avatar
yikes that sounds dangerous no? parked right lol?
throttle cable freeze something somewhere?
Old 01-11-2014, 12:27 PM   #3
The Radium King's Avatar
frozen/gunked-up icv (or carb jets depending ...). get it in a heated garage overnight and see if you still have the problem in the morning?
Old 01-11-2014, 12:28 PM   #4
recycledsixtie
recycledsixtie's Avatar
If you don't get an answer here try Pelican Parts Off Topics discussion. Lots of talent there to answer....
G
Old 01-11-2014, 12:37 PM   #5
Rennzenn
j.fro's Avatar
I had a 1990 2.9l Ranger for a while. Never had that problem, but for the problems it did have I found some pretty good ranger forums. I think one was called Ranger Station. The help is out there...
Old 01-11-2014, 12:38 PM   #6
There are a couple of pretty good Ranger forums out there. I have found them very helpful when troubleshooting my B4000.
'99 black 986
Old 01-11-2014, 01:13 PM   #7
Timco's Avatar
Fuel injected. It lives indoors at my shop or in my garage when it snows. Cable not sticking, it's an electronic or idle issue.
I'll check ranger forums. Thanks.
Old 01-11-2014, 01:15 PM   #8
vacuum leak?
( trks guide to troubleshooting - first assume something is dirty. if not, assume some cheap piece of plastic or rubber has broken or come unattached. if not, then i gots troubles ...)
Old 01-11-2014, 01:23 PM   #9
BYprodriver's Avatar
FixOrRepairDaily JK
Old 01-11-2014, 02:02 PM   #10
Timco's Avatar
Idle air control valve
Throttle position sensor
Dirty throttle body
Old 01-11-2014, 02:03 PM   #11
Timco's Avatar
FixOrRepairDaily JK
Found
Off
Road
Digging
Old 01-11-2014, 02:30 PM   #12
Found On Road Dead
'99 black 986
Old 01-11-2014, 04:21 PM   #13
Timco's Avatar
Found On Road Dead
209k and only one valve spring!
I've busted the leaf springs, gone through 6 clutches, how many shocks and ball joints, and so on. Was surprised it's just a 4wd with a pushrod 6. Very basic. Maybe 3+ oil leaks and a small coolant leak. Head gasket time soon.
Old 01-11-2014, 05:23 PM   #14
jcb986's Avatar
Sounds like you have had a good time with er. Now is the time to retire the old girl. Or, wait for the next Tow, Drag In Sale and get $10 grand for er.
Old Hippie Young Heart
Old 01-11-2014, 07:20 PM   #15
Fast Only Rolling Downhill
Old 01-13-2014, 09:38 AM   #16
Gary D
Sounds like the Idle Air Control could be sticking. That would usually throw a code though. I would pull that and clean the contacts first.
Also make sure the air conditioning compressor isn't activating intermittantly (bad relay), that would cause the same issue. Remember, the heat system runs through the compressor at certain settings.
Gary_d is offline   Reply With Quote
