Old 11-13-2013, 06:57 PM   #1
2000 Boxster has rough idle and these codes
Hi everyone, I'm experiencing a rough idle on my boxster. I hooked up the Durametric and I have the following codes:
P code 174
P code 62
P code 65 cyl 3 misfire
P code 63 cyl 1 misfire
P code 64 cyl 2 misfire.
I had a misfire on a single cylinder a year or more ago and it was a hairline crack in a coil-pack. Any ideas what would cause 3 cyl. to miss all at once?
I only replaced the 2 worse coil-packs last time. But its been running great until recently. I replaced the CPS which cured my hot-starting issues. The roughness seems to smooth out with increased rpm's although Its probably just less noticeable.
Any input greatly appreciated.
Thanks,
Garry
tradergarry is offline   Reply With Quote
Old 11-14-2013, 01:12 AM   #2
tomc88's Avatar
I'm no expert but I had misfire on 4,
and it was my AOS that had failed
2001 Boxster S
tomc88 is offline   Reply With Quote
Old 11-15-2013, 09:42 AM   #3
Hmm. I replaced my AOS about 2 years ago, but I'll check hoses to and from.
Thanks,
Garry
