Old 09-26-2013, 12:24 AM   #1
Boxster 986 usable wheel sizes?
I'm buying winter wheels for Boxster S (year 2000) and would like to know more about what wheel sizes I can use. Manual says only these sizes:
17-inch:
front 7Jx17
rear 8.5Jx17
Offset 55mm, 48mm, 50mm
18-inch:
front 7.5Jx17
rear 9Jx17
offset 50mm, 52mm
Now I'm specially interested can I put 16-inch wheels like these:
front 6x16, offset 50mm
rear 7x16, offset 40mm
without any modifications (spacers etc.)?
or can I put these kind of 17-inch wheels?:
front 6.5x17, ET55
rear 8x17, ET40
Does the car's behaviour change a lot if I choose to take either those 16-inch wheels or those 17-inch wheels specified there or do they even fit to the car straight away?
Thanks in advance!
Mikluuutus is offline   Reply With Quote
Old 09-26-2013, 05:46 AM   #2
steved0x's Avatar
The 16" wheels don't clear the bigger brakes on the S model. Maybe some aftermarket ones do but I believe 17" is the minimum size for the S.
Steve
Ps I am in FL so I know very little of winter wheels ��
Old 09-26-2013, 06:25 PM   #3
Track rat
Topless's Avatar
16s won't clear your "S" brakes The 40 offset 17s will probably rub depending on tires chosen. Choose a set of Boxster takeoff 17s for cheap. You can run 205/225 widths on stock 17 rims.
Old 09-27-2013, 05:04 AM   #4
Ok thanks, glad I didn't buy 16" wheels and after that find out they won't fit!
I would accept 17" Boxster takeoff wheels but do you guys know someone who would be selling them in Europe in resonable price? Only ones I have found are the ones with some big scratches and still the price is 800-900$ which I think is way too high.
