Old 09-22-2013, 08:29 AM   #1
PaulDash's Avatar
Interior light swap possible?
The interior light in the overhead cluster on my '99 is loose. Instead of replacing it (looks like a cheap VW part, like the ones I had on my 944), I'm thinking of getting the facelift cluster; the one with the orientation light.
Question: will the orientation light work on my pre-facelift model? Is there an electrical hookup/relay that needs to be added?
PaulDash is offline   Reply With Quote
Old 09-22-2013, 08:52 AM   #2
urban's Avatar
I'm interested in this too!
urban is offline   Reply With Quote
Old 09-23-2013, 12:40 PM   #3
PaulDash's Avatar
104 views and no suggestions? Am I in the right section of the forum?
Old 09-23-2013, 12:59 PM   #4
I have no idea what you're talking about...the interior "dome" light?
Old 10-04-2013, 02:28 PM   #5
PaulDash's Avatar
You know the interior light between the sun visors? There were two versions of this for the 986.
The question is, will the later version fit a car with the earlier version installed.
Old 10-04-2013, 07:25 PM   #6
I see. You may have to take the plunge and answer that question yourself.
Old 01-25-2015, 06:12 PM   #7
PaulDash's Avatar
So, as particlewave said, I can answer the question myself.
No, the two are not compatible.
First, they have different plugs. This was not hard to get around - just a little cutting and soldering.
Second, the orientation light doesn't light up with the ignition. It appears there must have been a re-design of the electronics along with the facelift.
Old 01-25-2015, 06:21 PM   #8
Does it physically fit, though? The electronics part is easy enough.
Old 01-25-2015, 06:50 PM   #9
PaulDash's Avatar
Yes, it physically fits.
The electronics would have to be redone probably at the relay. It seems that in the post-facelift lamp, the orientation light LED constantly draws power from the +12V going to the lamp and is switched off with a time-out after locking the car. I'm guessing here as I don't have access to a post-facelift car.
Old 10-15-2016, 10:05 AM   #10
KevinH1990's Avatar
Any recent updates on this topic? I've been searching, but haven't found any other threads.
Old 10-15-2016, 10:42 AM   #11
KevinH1990's Avatar
I did a little more searching and found this
http://986forum.com/forums/general-discussions/58525-dome-light-swap-97-04-type-possible.html
I had been searching on "interior light." When I searched on "dome light" I found what I needed.
It looks like the swap is possible with a little electrical work. The plastic tabs on my light broke when I pulled it out to replace the bulb. (I was careful, but I guess 17-year old plastic just gets brittle.)
I found a 2004 assembly for $28 shipped on Ebay, so I might as well give this a shot. If anyone has any additional tips or links, please share them.
