Old 09-20-2013, 09:33 AM   #1
mikesz's Avatar
Replacing engine bay fan
My engine bay coolant fan is not working. I replaced the relay and can hear it clicking when I hook up my Durametric but fan does not go on. The fuse is good so I am thinking the fan is shot. Is there a DIY to explain how to do this?
99 Porsche Boxster
Old 09-20-2013, 10:41 AM   #2
Trey T's Avatar
I've never serviced it but it's a single speed and should only have two wires.
Get a digital multimeter (DMM) and determine ground and test it directly to battery. Sorry for not be detail but hopefully someone can chime in and describe more.
Trey T is offline   Reply With Quote
Old 09-23-2013, 04:44 PM   #3
mikesz's Avatar
I think I need to clarify. I have a durametric. when I hook it up and try to test the engine bay fan I can hear the relay clicking but the fan does not go on. I checked the fuse and its good but still fan doesn't go on. when I pull out the relay and use a jumper the fan goes on no problem and runs strong. So why would the fan work fine with the jumper and not using the durametric?
99 Porsche Boxster
Old 09-23-2013, 05:41 PM   #4
AKnowles's Avatar
Based on your testing, I'd say you have a bad relay. After all, it works when you use a jumper. Just because a relay clicks does not mean the contacts are making contact or that the contacts are not burned/pitted and unable to handle the current flow.
Old 09-23-2013, 06:34 PM   #5
Porsche "Purist"
Paul's Avatar
+1 ^^^^^^^^
1987 924S. 2002 996TT. PST-2
Old 09-24-2013, 04:15 AM   #6
mikesz's Avatar
ok I ordered a new relay.
99 Porsche Boxster
