Old 11-16-2013, 11:04 AM   #21
Verhag's Avatar
Originally Posted by haz View Post
That's it? Is the construction useless?
Please, will somebody specify exactly what valve, or post a part number? This has nothing to do with wind flow...the "howling" or "whirring" noise from near gas filler cap immediately goes away when you lift off accelerator.
In this thread, at least 3 different valves are cited as the problem. Driving me nuts, would love to order correct part and take care of it. Thank you.
1997 C4S
2000 Boxster S
Verhag is offline   Reply With Quote
Old 11-16-2013, 05:20 PM   #22
TRPLBLK04's Avatar
Same howl. Just applied the tape trick. Give it a test tomorrow..............Cheers.
TRPLBLK04 is offline   Reply With Quote
Old 11-16-2013, 07:46 PM   #23
Verhag's Avatar
Who says Porsches are expensive to maintain?....Thank you TRPLBLK04....covered the hole with a piece of duct tape tonight.....whirring, howling sound is gone!
You just saved me at least $100!
1997 C4S
2000 Boxster S
Old 11-25-2013, 09:58 AM   #24
TRPLBLK04's Avatar
Good to here Verhag.......worked for me as well.
Old 11-25-2013, 12:10 PM   #25
haz
haz's Avatar
I did nothing and now the noise is all gone. I donīt understand my car.
haz is offline   Reply With Quote
Old 01-04-2014, 09:33 AM   #26
haz
haz's Avatar
Noise has returned. Sealing the hole under the gas filling place does not make it go away, as suggested below.
Anyone have any other tips as to what the noise could be?
Old 01-04-2014, 05:38 PM   #27
TRPLBLK04's Avatar
Hello haz. Just wanted to ask if you sealed correct hole? Its not the one below gas cap, thats drain overflow hole. Its to the far right, when gas fill door is open, it would be under bottom edge of door. Mine pictured here (thou not a good pic) you can see the strips of white electrical tape i sealed mine with. Just thought i whould mention as mine has no howl for over a month now..............Cheers.
Old 01-05-2014, 03:05 AM   #28
haz
haz's Avatar
Yup I found the Hole and tried to block it but no effect.
Old 01-13-2014, 02:30 PM   #29
Verhag's Avatar
Must have been wrong hole...noise was back next morning...based on your recent posts, need to go back and search again for correct hole...pic not much help....driving me nuts!
1997 C4S
2000 Boxster S
Old 01-13-2014, 11:11 PM   #30
haz
haz's Avatar
+1 fggegrege
Old 01-27-2014, 01:34 PM   #31
Verhag's Avatar
Fixed again
+1 fggegrege
Removed tape from hole beneath filler cap, covered hole in front...noise gone. Is this tape covered hole going to cause its own problem?
Thanks for the tip
1997 C4S
2000 Boxster S
