Old 09-08-2013, 09:54 AM   #1
jaykay's Avatar
Mesh grills
I am creating some mesh inserts for my side vents and need a reversible bonding agent for the mesh to plastic. So it can go back to stock. Any ideas? I was going to try wind shield adhesive. I done it before up front but I can't get a hold of that stuff anymore
986 00S
Old 09-08-2013, 10:36 AM   #2
Nine8Six's Avatar
You'll get the idea.
Don't mount the clip with a fasteners, use HOT glue instead or epoxy if you are worry. Degrease the ABS plastic before doing anything. Clips are 1mm thick aluminum, easy to custom-cut and flexible.
Old 09-08-2013, 10:46 AM   #3
jaykay's Avatar
Thanks!!! Hot glue is a great idea....will it hold?? I didn't think of it I think am going a bit brain dead these days
So hook in the clips and glue the the tabs to the plastic...great idea!
Where did you get the clips from???
986 00S
Old 09-08-2013, 12:21 PM   #4
Nine8Six's Avatar
Tabs, that is the term I was looking for thank you sir. Took the idea from my fiberglass aftermarket bumper. Has many of those to hold the mesh.
RE hot glue or not. Your guess is as good as mine. I bet the air filter is strong enough for a little tab but you never know. I would personally bother to use good A/B epoxy but given you degrease the housing with brake cleaner (for instance), that should ruff the ABS plastic enough so the HOT glue stick almost permanently. Dunno, not 100% sure.
I'd say epoxy if you ask me.
Old 09-08-2013, 12:28 PM   #5
Nine8Six's Avatar
Just make them yourself. I'd say any aluminum of 1-2mm thickness would do the trick. Food grade tin can maybe, anything really
Old 09-08-2013, 06:01 PM   #6
ccstud17's Avatar
i have had issues with hot glue! but i have plastic mesh so it moves/twists, the metal mesh might be a better wtih hot glue, but if it acts anything like my plastic mesh AVOID IT! I have a 50% re glue ratio, and im using the industrial strength yellow stuff.
Stop lights timed for 30 MPH, are also timed for 60 and 90 MPH!
ccstud17 is offline   Reply With Quote
Old 09-09-2013, 03:55 AM   #7
edc
550 Anniversary
edc's Avatar
Can you get the Zunsport (UK) metal mesh clip grilles in the US? I have these and they are great and very simple to fit.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
