Old 01-17-2006, 09:01 PM   #1
Key light on remote continuosly on, any help??
Tonight the red light on the key remote went on and stayed on continuosly. The remote would not work when this happened. So, I took key apart, took battery out, replaced same battery, still have same problem. I thought maybe the buttons were stuck but I took the piece out of the key head and pushed the buttons and that doesn't help. I finally now have taken the battery completely out so I don't run it down while trying to figure out what's wrong. Any help or anyone had this happen before??
Thanks,
Mike
thenavarro is offline   Reply With Quote
Old 01-18-2006, 12:11 AM   #2
I do not remember this problem until the 3 button remote came out in 2001.
Try a new battery. If that does not work then put the battery in upside down for 10 seconds, then put it back in the correct way. If that does not work the remote may need to be replaced.
Old 01-18-2006, 02:30 PM   #3
Thanks Toolpants, I'll give it a try when I get home tonight.
Mike
