Old 08-26-2013, 10:08 AM   #1
Renew headlight
Hi, I would like to have some better looking headlights, My first idea was to polish the front glass to renew it but I am not sure, do you have some ideas ?
Thank you
2003 Boxster S
The French Dude is offline   Reply With Quote
Old 08-26-2013, 10:21 AM   #2
AKnowles's Avatar
I cleaned and polished a used set of Lintronics I bought off of eBay and thought it well worth the investment in time, effort, and money. You can search or the thread to see the results.
Old 08-26-2013, 11:09 AM   #3
madmods is offline   Reply With Quote
Old 08-26-2013, 12:37 PM   #4
If yours are "flaky" looking as mine were, you may need to wet sand them with #1000 and then work your way up with finer grits and buffing compounds. I found it much easier to pull the headlights and strap them down to to a work surface and use a power buffer for the final stages. I have a plastic restoration kit with two grades of polishing compound.
Wret is offline   Reply With Quote
Old 08-26-2013, 12:53 PM   #5
Old 08-26-2013, 01:53 PM   #6
Thank you guys, I just had the job done with Meguiar's Headlight and it done exactly what I wanted !
2003 Boxster S
