Old 08-20-2013, 02:56 PM   #1
Install Hardtop
I need to install the lock insert for a new hardtop that I bought from the forum.
I need some help in understanding how do you get to the bolt that holds the peg lock in the bracket on the car?
rbrown is offline   Reply With Quote
Old 08-20-2013, 03:43 PM   #2
Joe B's Avatar
Pelican Technical Article: Installing the Boxster Hardtop and Installation Kit - 986 / 987
Fiddly, but not terribly difficult. Be sure and do the hold-the-shoulder-bolt-with-a-baggy trick. The job is much easier, and you can actually see what you are doing, if you remove the carpeted pieces behind the seatbelts. Do a search. I found this on Google (your friend ):
http://986forum.com/forums/general-discussions/1607-hardtop-installation-question-print.html
Old 08-20-2013, 04:44 PM   #3
Remove the carpet piece, its so much easier.
Later
Chris
wawa is offline   Reply With Quote
