Old 08-09-2013, 07:39 AM   #1
batshapedheart's Avatar
Emblem Switch
I bought a new Brushed Titanium emblem for Porsche.
After I removed the speednuts I found what appears to be some sort of rubber washer on them but they were dried and cracked and broke in my hands.
Does anyone know where can I find those or a solution to that?
2002 Boxster 2.7
batshapedheart is offline   Reply With Quote
Old 08-09-2013, 07:45 AM   #2
Perfectlap's Avatar
I'm no expert but I would try piecing them back together with gorilla glue and then spraying them with that rubber in a can spray. But then again, you can replace anything on the internet. Measure the diameter and search for x mm rubber gasket.
p.s.
Please post the link for the Ti emblem. That sounds expensively cool.
Old 08-09-2013, 07:52 AM   #3
I got it from Wheel Dynamics, I think its real cool looking. I'm trying to take all the gold/amber from the car
2002 Boxster 2.7
Old 08-09-2013, 08:22 AM   #4
That's just sealant. Use a dab of black rtv silicone on the back of each post to re-seal.
Old 08-09-2013, 08:38 AM   #5
^ yup, I changed my emblem about 3 weeks ago. Just filled the speed nuts with a healthy glob of auto glue so it will completely seal the holes and screw them back on.
mump is offline   Reply With Quote
Old 08-09-2013, 08:53 AM   #6
Perfectlap's Avatar
won't that create too much torque on the other side when removed? Seems like silicone or glue would bond/harden to the paint.
Old 08-09-2013, 09:10 AM   #7
Just a little bit of silicone on the inside of the hood, not the outside (between speed nut and inside of hood).
It just creates a seal around the post holes, not enough to bond anything
Old 08-09-2013, 12:40 PM   #8
Go to your local hardware store, and head to the fastener isle, there will be a row of thousands of tiny (machine) rubber washers, just find one that has the right size and go.
Speedy2000 is offline   Reply With Quote
Old 08-09-2013, 02:10 PM   #9
Actually, a washer wouldn't seal around the post and would allow play to develop, possibly even causing the speed nut to fall off. This is why a mildly adhesive sealant is used
Keeps a good seal and prevents the speed nut from backing off.
Old 08-10-2013, 06:28 AM   #10
I just replaced them when I fitted a new emblem to the boxster ....
Ian c is offline   Reply With Quote
Old 08-10-2013, 09:16 AM   #11
Keith Newby's Avatar
The dealer should supply those emblem speed nuts. The early nuts didn't have a rubber gasket and they scratched the paint as a result. I replaced the fasteners with a short length of surgical tubing on my early 911 and 912 restorations. The surgical stuff doesn't harden, is easy to remove when detailing the car, and they hold fast.
Keith Newby is offline   Reply With Quote
